Mikkel Vesterled
Alt der er opslået af Mikkel Vesterled
  1. Hi Found the answer: https://github.com/openhab/openhab2-addons/issues/2782 Check out weakfl's post: your.items example Dimmer KitchenCeilingLight "Deckenlampe" <light> (gKitchen, gLights) { channel="zigbee:device:XYZ_1_switch_level" } Dimmer KitchenCeilingLightHomeKit "Deckenlampe" <light> (gKitchen) [ "Lighting" ] your.rules example: // Kitchen Ceiling Light rule "KitchenCeilingLightHomeKit" when Item KitchenCeilingLightHomeKit received command then if (receivedCommand != ON && receivedCommand != OFF) { KitchenCeilingLight.sendCommand(receivedCommand) } else if (receivedCommand == OFF) { KitchenCeilingLight.sendCommand(0) } end rule "KitchenCeilingLight" when Item KitchenCeilingLight received update then val level = KitchenCeilingLight.state as Number KitchenCeilingLightHomeKit.postUpdate(level) end
  2. Hi I have just set up openHAB2 on a Windows machine and it seems to work with IHC and HomeKit integration. One question is how I set up dimmers correctly so that I can dim the lights from the Home app. Is this possible? The normal switch "LysMathias" works just fine and turns on/off via the Home app. The dimmers does not work (lights are not dimming when trying from the Home app), but I see that openHAB2 get the changes from HomeKit. I tried using the IHC IDs both from the output and input without any luck. My OpenHAB.log returns some errors, but I believe this could relate to the answer above. Correct me if I am wrong. Using newest IHC binding (version 2.4.0.201812081313). .items Switch LysMathias "Loft Lys Mathias" <light> ["Lighting"] {ihc="77915"} Dimmer Sofabord "Sofabord" <light> ["Lighting"] {ihc="7147282"} Dimmer Spisebord "Spisebord" <light> ["Lighting"] {ihc="29020"} events.log 2019-01-16 21:43:50.341 [ome.event.ItemCommandEvent] - Item 'Spisebord' received command OFF 2019-01-16 21:43:50.357 [vent.ItemStateChangedEvent] - Spisebord changed from 100 to 0 2019-01-16 21:43:51.185 [ome.event.ItemCommandEvent] - Item 'Spisebord' received command ON 2019-01-16 21:43:51.185 [ome.event.ItemCommandEvent] - Item 'Spisebord' received command 100 2019-01-16 21:43:51.653 [vent.ItemStateChangedEvent] - Spisebord changed from 0 to 100 2019-01-16 21:43:53.762 [ome.event.ItemCommandEvent] - Item 'Spisebord' received command ON 2019-01-16 21:43:53.762 [ome.event.ItemCommandEvent] - Item 'Spisebord' received command 48 2019-01-16 21:43:54.090 [vent.ItemStateChangedEvent] - Spisebord changed from 100 to 48 2019-01-16 21:43:56.059 [ome.event.ItemCommandEvent] - Item 'Spisebord' received command OFF 2019-01-16 21:43:56.074 [vent.ItemStateChangedEvent] - Spisebord changed from 48 to 0 openhab.log 2019-01-17 08:03:14.536 [ERROR] [lfe.hap.impl.http.impl.BinaryHandler] - Exception in binary handler java.io.IOException: En eksisterende forbindelse blev tvangsafbrudt af en ekstern vært at sun.nio.ch.SocketDispatcher.read0(Native Method) ~[?:?] at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:43) ~[?:?] at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:223) ~[?:?] at sun.nio.ch.IOUtil.read(IOUtil.java:192) ~[?:?] at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:380) ~[?:?] at io.netty.buffer.UnpooledUnsafeDirectByteBuf.setBytes(UnpooledUnsafeDirectByteBuf.java:447) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:880) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:242) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:119) [226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:511) [226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:468) [226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:382) [226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:354) [226:org.openhab.io.homekit:2.4.0] at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) [226:org.openhab.io.homekit:2.4.0] at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:137) [226:org.openhab.io.homekit:2.4.0] at java.lang.Thread.run(Thread.java:748) [?:?] 2019-01-17 08:03:14.536 [ERROR] [.hap.impl.http.impl.AccessoryHandler] - Exception caught in web handler java.io.IOException: En eksisterende forbindelse blev tvangsafbrudt af en ekstern vært at sun.nio.ch.SocketDispatcher.read0(Native Method) ~[?:?] at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:43) ~[?:?] at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:223) ~[?:?] at sun.nio.ch.IOUtil.read(IOUtil.java:192) ~[?:?] at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:380) ~[?:?] at io.netty.buffer.UnpooledUnsafeDirectByteBuf.setBytes(UnpooledUnsafeDirectByteBuf.java:447) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:880) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:242) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:119) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:511) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:468) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:382) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:354) ~[226:org.openhab.io.homekit:2.4.0] at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) [226:org.openhab.io.homekit:2.4.0] at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:137) [226:org.openhab.io.homekit:2.4.0] at java.lang.Thread.run(Thread.java:748) [?:?]
