LarsC
49 -
Alt der er opslået af LarsC
I looked at rules aswell, but for my purpose it feels like overkill when I do not want any ekstra functionallty besides updating values. Btw. everything works as expected now, even my OpenWeatherMap to IHC communication - and of course back to Homekit for iphone control of everything.
Thanks @Pauli Anttila Got it working with profiles.
I actually think I got the solutions now ! I had to use the profile option on my item. Number Temperature_Kontor "Temperatur Kontor [%.1f °C]" <temperature> [ "CurrentTemperature" ] { channel="mqtt:topic:node-red:mqtt_temp_kontor", channel="ihc:controller:elko:ihc_temp_kontor" [profile="follow"] } Only minor issue is that I have to restart OH every time i change anything in my items before it will, even though it updates after every save.
@Pauli Anttila Hi Pauli, Any hints or suggestions to why my items do not update the IHC value when a new mqtt message arrives ? In version 1.0 I used: Number Temperature_Kontor "Temperatur Kontor [%.1f °C]" <temperature> [ "CurrentTemperature" ] { mqtt="<[mqtt:temp/kontor:state:default]", ihc=">0x410f14" } Here in 2.0 I use: Number Temperature_Kontor "Temperatur Kontor [%.1f °C]" <temperature> [ "CurrentTemperature" ] { channel="mqtt:topic:b5bd6b00:kontor", channel="ihc:controller:elko:temp_kontor" } When I manually click 'ok' under PaperUI->controls it updates fine with the received mqtt value into IHC
Det er lige præcis det. Med ver. 1.0 brugte jeg følgende linje i items: Number Temperature_Kontor "Temperatur Kontor [%.1f °C]" <temperature> [ "CurrentTemperature" ] { mqtt="<[mqtt:temp/kontor:state:default]", ihc=">0x410f14" } Det har virket upåklagelig. Jeg prøver Pauli
I paperUI under control, der kan jeg se mine temperaturer, og de bliver fiont opdateret her, fra mqtt. Når jeg trykker ok på den, så bliver værdien sent til ihc som den skal. Alt dette sker bare ikke automatisk
Værdierne fra mqtt kommer fint ind i mine items, og det samme kan jeg få mine ihc værdier til. Men udfordringen er at få dem sendt til ihc igen. Hvis jeg i paperUI blot trykker på 'ok' på værdien efter mqtt har opdateret den, så bliver den fint sent til ihc. Så den opdatere min item, men får den ikke afsendt til ihc ved opdateringen.
Hej, Jeg er ved at lave min OH2 om til at bruge den nye binding. I den forbindelse har jeg dog lidt udfordringer med at få den til at skrive en værdi ind i IHC som jeg modtager fra en mqtt besked. Når jeg sætter en værdi i paperUI, så opdaterer den fint ind i controlleren. Når der kommer en ny besked fra mqtt, så bliver værdien fint ændret igen i OH, men den kommer bare ikke videre til IHC. Så det er lidt som om at den mangler en trigger når værdien kommer fra mqtt ? things: Channels: Type number-channel : temp_kontor "Temperatur Kontor" [ resourceId=4263700, direction="WriteOnly" ] items: Number Temperature_Kontor "Temperatur Kontor [%.1f °C]" <temperature> [ "CurrentTemperature" ] { channel="mqtt:topic:b5bd6b00:kontor", channel="ihc:controller:elko:temp_kontor" }
It works here aswell ! Good job !
Initially I could not click on the manually created channel either, but after a page refresh I could. I just used some random channel and ressource id
Hi Pauli, and thanks for an updated add-on ! I have the same issue as Ejvind, I have tried an force-refresh (ctrl+f5) it does not change anything.
Der findes masser af alarmsystemer som også har en event baseret tilgang til programmering. Jeg bruger selv en Lares alarm som sætter nogle relæer høj/lav alt efter om der er alarm, fuld eller del tilkoblet. Dem har jeg så monteret over i min ihc og på den måde kan jeg så både få status i ihc, og muligheden for at til/fra koble fra ihc. Det giver nogle fede muligheder med at aktivere en sluk alt, ved fuld tilkobling, og tænde lys ved frakobling hvis skumring er aktiv. osv osv osv..
Integration til BlueSound
Best practice Openhab2 (binding ver 1), Homekit og IHC
question svarede på LarsC's EjvindHald i OpenHAB
Det lyder godt! Langt tryk har jeg heller ikke noget at bruge til, jeg laver den enten direkte ind i fb'en eller også bare et 'fiktiv' tryk som jeg kan ramme fra openHab. homekit delen har jeg styr på. -
Jeg er ved at prøve og lave et tryk i homekit som skal aktivere en funktionsblok (sluk alt). Ønsket er at den blot skal sende en puls til fb'en Men jeg synes pinedød ikke jeg kan få den til at aktivere den. Jeg har en masse andet kørende, som dog går direkte ind på output istedet, det fungere fint. Er der nogen som har en linje fra ihc.items der virker, som jeg må se ? og det er vel bare resource_input id der skal linkes til ? -
Hej, Hvordan håndtere i eksempelvis et sluk alt scenarie. Jeg har overvejet om man bør oprette en lokalitet som hedder eks. scenarier, heri vil jeg så lave en helt enkel fb som slukker alt det relevante. I mit soveværelse vil jeg så lave en fb med et langt tryk som kalder ovenstående scenarie. Derudover vil jeg i min alarm lokalitet kalde min sluk alt fb ved tilkobling af alarm. osv. På den måde kan jeg genbruge min sluk alt, men er det måden at gøre det på for at holde det enkelt og mere OOP 'agtigt' ?
Wireless dæmper Ø80 udtag version 2: Valg af LED lyskilde
question svarede på LarsC's Benjamin korsgaard i Projekter
Jeg bruger Philips MasterLED (3000K) de kører helt perfekt (96stk) -
Er udfordringen med at man ikke kan kommunikere med ihc controlleren, så længe ihc bridge er aktiv blevet løst ? Jeg har ihvertfald problemer, både med at logge ind i ihc admin, samt bruge openhab - så længe ihc bridge kører. Med det samme jeg ændre ip adressen til controlleren inde i ihc bridge, så kører det andet.
Måske man bare kan finde den manuelt indtil ? Jeg har lige snippet fra min vis fil. <product_dataline id="_0x362f53" product_identifier="_0x2124" name="Temperatur sensor" locked="yes" icon="_0x83" note="Temperatur sensor med rum- og gulvføler" position="I loft"> <resource_temperature id="_0x363014" name="Rumtemperatur" inivalue="20.00" accessibility="read"/> <resource_temperature id="_0x363114" name="Gulvtemperatur" note="Valgfri ekstern gulvføler" inivalue="20.00" accessibility="read"/> <resource_input id="_0x363211" name="Alarm" icon="_0x36" note="Høj ved fejl" accessibility="read"/> <resource_temperature id="_0x363314" name="Kalibrering af rumføler" note="Offset fra målt temperatur" setting="yes"/> <resource_temperature id="_0x363414" name="Kalibrering af gulvføler" note="Offset fra målt temperatur" setting="yes"/> <settings id="_0x363525" name="Indstillinger" note="Produkt indstillinger"> <dataline_input id="_0x36365a" name="Temperatur sensor indgang"/> </settings> </product_dataline>
Men det bliver vel ikke værre end det allerede er ? Edit: Hov vent, er det ikke kun via home/eve at den ryger op på max ved tænd ? hvis man bruger sit ihc tryk er der vel ingen fejl efter den nyeste opdatering, eller har jeg misforstået ?
Type Signal Der Sendes Fra Fx Temp. Sensor Til Ihc Input
topic svarede på LarsC's Guitarans i Tredjepart Produkt
Hej Mikkel, Af ren og skær nysgerrighed, hvordan er dit liv ? Har du evt. nogle hints til hvordan jeg kan sætte en værdi direkte via http ? -
Er der kommet en løsning på at dimmere ikke kører op på fuld hammer ca 1-2sekunder efter tænd ? Bortset fra det, så kører det jo bare fantastisk. Oplever ingen fejl med manglende forbindelse mv. - nu mangler jeg blot at få kørt nogle temperaturer ind også.
