Lars1
  • Days Won
    111
Alt der er opslået af Lars1
  1. Sorry to hear that, but not surprisingly, since the Visual 3 controller was never sold outside DK.
  2. Lars1
    Ihc tryk og wiser
    Wiser og LK IHC er to MEGET forskellige teknologier. De fungere IKKE samme. De kan faktisk slet ikke kommuniker med hinanden, da LK IHC wireless benytter Wavenis protokollen, mens Wiser benytter Zigbee. Wiser er dog ikke designet til kun at fungere med deres egne komponenter. Wiser funger sammen med andre produkter som benytter Zigbee protokollen, men der kan være kompabilitets udfordringer, da ikke alle Zigbee produkter overholder standarden 100%
  3. Well. If that's what you prioritize, I would look at Zwave or Zigbee products instead. They are both decentralized too, and are open standards with multiple vendors. With Shelly you really need to look at the details of their full portfolio. As far as I remember not all of their components works on WI-FI, which is the main reason why I decided not to go with them. Did you get in contract with Schneider, and what did they say? My controller was replaced free of charge less than 6 months ago. I only had to pay for the return shipment.
  4. I got mine replaces about 3-6 months ago. Schneider got a number of Visual 3 controllers back from the technical schools, and they have been able to refurbished some too. Go to lk.dk and click on support. There you will see all the contact info's. My experience is that they answer the phone pretty quickly, but the support form is slower and you might not get an answer at all.
  5. I haven't switched to Shelly, but I've looked at it and decided it's not the right way for me. It's a while back, but as far as I remember the reason is that it's using various communication standards depending on the components, and not all supports all communication standards. You therefore risk having a mixed setup. On top of that, I think there were some strange things with how you control the dimmers. Regarding KNX, please bear in mind that it's not a proprietary product like LK IHC. It's an industry standard, which means there are multiple vendors, so if one decides to drop KNX you still have other vendors to choose from. I'm not 100%, but I actually think Shelly is proprietary like LK IHC, which means you have a greater risk ending up in the same situation with Shelly than with KNX.
  6. It sounds like what happened to my Visual 3 controller too. I called LK and got it replaced. Alternatively, you need to look for an used Visual 2 controller. It will work just as fine as the Visual 3 controller, unless you have LED dimmers, as Visual 2 doesn't support those.
  7. Det er korrekt at LK IHC ikke længere produceres, men bortset fra Visual 3 controlleren (som endnu kan ombyttes ved at ringe til LK), er det RIGTIGT stabilt produkt, hvor flere af de installationer som blev lavet tilbage i slut 90'erne da det kom frem, fortsat køre idag uden problemer. Det som plejre at gå i stykker er strømforsyningen, men det er en standard 24VDC strømforsyning, så den kan nemt erstattes. Derudover er LK IHC HW kompatibelt på tværs af versionerne, hvilket vil sige at de I/O moduler som blev brugt sammen med den første LK IHC controller er de samme som blev brugt sammen med den seneste. Har man en gammel TermIHC installation, kan man opgrader installationen ved bare at skifte controlleren. Den anden vej er også mulig, men man kan så ikke benytte den funktionalitet som kom med de nyer controller. At en elektriker taler dårligt om LK IHC undre mig ikke. De vil jo gerne sælge dig noget nyt. Jeg tror aldrig jeg har mødt en håndværker som taler godt om et udgået produkt. Som med alt andet som er udgået, eller er gammelt, så har man en udfordring hvis det går i stykker. Der er dog jævnligt IHC installationer som bliver sat til salg fordi der bliver erstattet af noget andet, så hvis man vil sikre sig, kan man købe nogle brugte komponenter som reservedele. Men hvis din installation ikke er ret stor,kan det være den nemt kan erstattes med noget andet. Prøv evt. at tage et par billeder af din LK IHC tavle, så kan vi hurtigt give dig et bud på hvor stor din installation er. Bruges den kun til lysstyring, kan den sikkert nemt skiftes til noget andet, men bruges den også til varme og alarm, er det straks mere komplekst. Omkring softwaren. Alt efter hvilken IHC controller du har, findes der forskellig versioner af softwaren, men det findes altsammen kun til windos. Alle versionerne kan gratis downloades fra mit lk https://www.lk.dk/mitlk/download-ihc-software/ Det kræver et login, men alle kan gratis oprette sig som bruger. Hvis du har en Visual controller vil du sammen med Visual softwaren få installeret en PDF fil som meget pædagoisk forklar hvad LK IHC er, hvordan det er bygget op, hvordan man programmer det m.m. Jeg vil KRAFTIGT anbefale at du læser denne. Det er den samme hvad enten du installer Visual 2 eller 3, og 95% gælder også for TermIHC og Visual 1, så læs den også selvom du ikke har en Visual 2 eller 3 controller. Du kan finde ud af hvilken LK IHC controller du har, ved at læse denne tråd https://www.ihc-user.dk/forum/forums/topic/11132-hvilken-controller-har-jeg/ Hvorvidt LK IHC er godt eller skidt afhænger af øjnene som ser på det. Personligt mener jeg fortsat at LK IHC er langt bedre end samtlige moderne smarthouse systemer, men det er designet tilbage i slut 80'erne/start 90'erne og siden Visual 2 blev frigivet i 2012 er det stortset ikke vidre udviklet, så har ikke en masse af de features som man ser med moderne smarthouse systemer. Tilgengæld er det et fuldt smarthouse system, og ikke kun lys styring som langt de fleste moderne smarthouse systemer. Derudover har det grundlæggende en stærk arkitektur som gør det flexibelt og nemt at integrer med andre ting via f.eks. OpenHab, Home Assistant, etc. Men det kræver at man er IT kyndig.
  8. Wavenis er en gamme protokol som stortset ingen benytter idag, så ikke så underligt at alle giver op over for den. Værd dog opmærksom på at Wiser og LK IHC ikke funger sammen. Det er 2 forskellige teknologier.
  9. Well. Sommetider har man brug for lidt baggrunds information for at forstå hvad der står skrevet. Mit problem er at jeg ikke rigtig kan se nogen grund til at tage strømmen til 2 wireless dimmer. Hvorfor ikke bare slukke for lyset ved at sætte lysstyrken til 0%. Derudover forstår jeg ikke hvorfor du ikke bare tester dit scenarie? Det vil ikke kræve meget at forbinde en wireless dimmer til en fortråedet udgang på et I/O modul, og så teste om den har samme lysstyrke når du igen tænder for den, som da du slukke for udgangen. Men fred være med det. Min erfaring de gange jeg har haft strømafbrydelse, er at wireless dimmer og andre wireless enheder for den sag skyld holder den tilstand de havde inden strømafbrydelsen, men mere vigtigt de holder også tilstanden selvom strømafbrydelsen kun rammer controlleren, og man ser ikke de hurtige on/off man sommetider ser på de fortåede I/O moduler når controlleren igen kommer op.
  10. Når der er strømafbrydelser, rammer det normalt alt strøm og ikke kun en enkelt fase, og som jeg skrev. Hvis du har batteri backup på din installation, vil du have et 24V OK signal, hvor du kan se om 24V strømforsyningen er ok, hvilket den ikke vil være hvis der er strømafbrydelse. Men igen. Jeg er ikke sikker på hvad det egentlig er du spørger efter.
  11. Jeg er ikke sikker på hvad du efterlyser, men hvis du har en LK IHC controller, så kan du programmer præcis hvad du ønsker der skal ske når strømmen kommer tilbage. Dels er der et power up event, og dels har du et 24V OK signal, hvis du har batteri backup på din installation.
  12. LK IHC wireless benytter Wavenis wireless protokollen, mens deres Wiser produkter benytter Zigbee. Håber dette hjælper dig videre.
  13. If you can ping the controller using LAN, it sounds like a PC problem. Maybe antivirus again? If you have telnet on your laptop, you can try telnet <IP> <web port>. It should give you a text version of the browser frontpage.
  14. @billekbh Det som @kjeldstrøm forsøger at sige er at LK IHC er 0V styret, hvilket vil sige at dine tryk skal have 0V. Ikke 24V for at virke. En LK IHC indgang går ON når der skabes forbindelse mellem 0V og indgangen. Skaber du forbindelse mellem +24V og indgange, sker der intet (har selv lavet den fejl et par gange)
  15. Is the LAN problem both with Visual and IHCStarter? What happens if you type in the IP of the controller in a browser?
  16. How do you try to connect? Visual, AdminView, ServiceView or something else? If AdminView or ServiceView are you using IHC starter or similar? If not, the problem is most like Java encryption issues. The workaround is to use IHC starter or similar, or follow the guide line in the FAQ threads.
  17. Jeg kunne godt være interesseret i det hele (minus wireless), men jeg ønsker ikke at komme i en bud krig med Bjarne og har dårligt tid til at lægge et bud på resten før end om 2-3 uger.
  18. LK IHC alarm LK IHC alarm, kan du få både brand og indbruds alarm. Dog er alle LK IHC røg og alarm PIR udgået, men de fungerede via et simpelt on/off signal, så enhver røg eller alarm PIR med et galvanisk overdragelses relæ eller tilsvarende kan bruges. Det eneste de skal gøre er at bryde en forbindelse mellem 0V og en indgang på et LK IHC input modul. LK IHC er dog ikke SKAFO (hedder det vistnok) godkendt, så alarm og forsikrings selskaber godkender det ikke som brand og indbruds alarm. Fælles antenne Jeg kan ikke ud fra dine billeder komme nærmere om det sorte kabel på loftet er terminerings punktet eller ej. Det eneste jeg kan sige med sikkerhed, er at den boks det terminer i er en antenne forstærker som ikke understøtter returvej og at det sorte kabel er signal forsyning til forstærkeren. Jeres nye router skal derfor helt sikkert sidde før antenne forstærkeren, men om den kan tilsluttes det sorte kabel på loftet kan jeg ikke sige. Et terminerings punkt vil normalt være et boks på væggen med et TV og et radio antenne udtag, men en løsning som jeres er også set før, så det kan ikke udelukkes at terminerings punktet er det sorte kabel på loftet. Umiddelbart vil jeg tro at de 2 hvide kabler fra antenne forstærkeren går til hver sin splitter på hvert sit loft, men for at være sikker bliver du nød til at følge kablerne. Det er dog lidt ligegyldigt i forhold til den nye internet router, da den skal sidde før antenne forstærkeren for at fungerer. LK IHC WIFI LK IHC WIFI kan alle sætte op. Teknisk set skal du bruge en elektriker til at sætte USB sticken i controlleren, da du skal pille låget af tavlen for at gøre dette, men du kan selv købe USB sticken og selv konfigurer den når den er sat i controlleren. Der er kun nogle få USB sticks, som funger sammen med LK IHC Visual 3 controlleren. Hvilke kan du se i den PDF samt online vejledning, som bliver installeret på din PC sammen med Visual 3 softwaren. Jeg vil kraftigt anbefale dig at læse PDF filen, da den giver en ganske god og pædagoisk introduktion til hvad du kan med din LK IHC installation. Den indeholder også en forklaring til hvordan du ændre programmet m.m. Men sørg for at få lavet en backup af det nuværende program, inden du begynder at ændre noget. Yderlig info På dine nye billeder kan jeg se at du har en del 12V trafoer. Jeg gætter derfor på at du har en del lavvolt halogen pære. Eftersom der er brugt installations kabel på både tilgangs og afgangs siden, samt at din LK IHC installation ikke ser ud til at indeholde dimmer, bør det være relativt simpelt at erstatte disse med LED's. Skulle jeg have overset en dimmer, er det straks mere kompliceret, da LK kun har deres LK IHC LED dimmer som understøtter LED's, og dem ser jeg ingen af. Skulle du ønske at dæmpe LED's findes der dog dimmer af andre fabrikater, som kan dæmpe LED's og fungerer sammen med LK IHC. Det kræver bare at de kan styres med on/off signaler eller tryk's
  19. Først. Tillykke med dit nye hus. Når jeg ser på dine billeder kan jeg se at en del kabler ikke er korrekt fastgjort og at der mangler afdækning flere stedder i tavlen og væg kanalerne. Jeg håber at det er noget som du får rettet op på, da din installation ikke er lovlig når den ser ud som på billederne. Derudover tvivler jeg på at din LK IHC installation kan betegnes som fuld LK IHC installation, da den ikke indeholder et batteri backup modul, og dermed næppe alarm delen. Om du har varmestyring via LK IHC kan jeg ikke se udfra billederne. Udover lys og varme styring, samt alarm findes der også LK IHC net til distribution af antenne signal, telefoni og netværk, altsammen via netværks kabler. Dette har du heller ikke. Vedr. din internet forbindelse, så skal din nye internet router forbindes til fælles antenne terminerings punktet i huset, da den har brug for en returvej i antenne kablet, og det ser din splitter og antenne forstærker ikke umiddelbart ud til at understøtte. Det er lidt svært at se om din fælles antenne forbindelse terminer på loftet eller et andet sted i huset. Din antenne splitter ser ud til at have fat i en antenne boks, som sandsynligvis er en antenne forstærker. Fra antenne forstærkeren, går der et sort antenne kabel, som meget tænkelig er forsyningen ude fra vejen, men det kan også være et internt kabel som kommer fra terminerings punktet i dit hus. Hvis der ikke sidder andet på antenne forbindelse mellem terminerings punktet og antenne forstærkeren, er det muligt at du kan overtale antenne selskabet til at installer den nye router på loftet. Hvis din nye internet router ender med at sidde et andet sted en på loftet, er der desværre ikke rigtig nogen vej uden om at få trukket et netværks kabel fra din nye internet router og til din router/switch på loftet, medmindre der ikke er andet tilsluttet på loftet en din IHC controller og det er en Visual 3 controller. I såfald kan du opgrader den til wireless med en USB stick. Alternativt findes der nogle løsninger med Ethernet over power (netværk via stærkstrøms installationen) eller man kan købe 2 wireless access points og sætte dem op i bridge mode (ikke alle access points understøtter dette). Begge løsninger er dog ikke noget den alm. dansker kan gennemskue at sætte op. Vedr. din nuværende router/switch opsætning, så giver den sorte router/switch ikke rigtig mening. Din nye internet router kommer sandsynligvs med wireless indbygget, og med mindre du har brug for mange kablede forbindelser, kan du bare tilslutte LK IHC controlleren direkte til din nye internet router. Du skal i den forbindelse måske ændre IP addresse på din LK IHC controller, eller lokal net opsætning i din nye internet router, således at LK IHC controllerne og lokal nettet på din nye internet router har samme IP netværks konfiguration. Derudover understøtter LK IHC controlleren ikke DHCP. Det er derfor vigtigt at LK IHC controllerens IP adresse IKKE ligger i DHCP området på din nye internet router. Evt. adgang til LK IHC controlleren fra internettet styres via port forwarding i din nye internet router, men det anbefales IKKE at give adgang til LK IHC controlleren fra internettet, da dens netværks stack er designet tilbage omkring år 2000. Den er med andre ord et stort sikkerheds hul. Håber du kan bruge ovenstående. Hvis der er spørgsmål vender du bare tilbage. Jeg vil dog kun være begrænset online de næste par uger, men der er nok andre som kan svare der.
  20. Jeg tror du misforstod hvad jeg skrev. Min kammerat ved udemærket godt hvad hvilke tryk styre. Han har selv lavet hele installationen. Han synes bare det er smarter at bruge telefonen i steddet for trykkene på væggen. Og vi griner af ham hvergang han går forbi trykkene for at hente sin telefon så han kan slukke eller tænde lyset.
  21. Dæmpning af alt andet end Ohmsk belastning er en komplex sag. At bruge en 10W LED til testen viser ikke andet end at den funger sammen med dimmeren, og er kraftig nok til at "overdøve" dit LED-bånd. Det er ikke unormalt at ikke dæmpbare LED's kan dæmpes hvis man kobler dem parallelt med en dæmpbar LED. Det er netop dette fænomen som dim-bob udnytter, uden at jeg dog har noget kenskab til den dim-bob som du linker til. Derudover er det heller ikke sikkert at du vil kunne dæmpe dit LED-bånd hvis du i stedet for en 10W dæmpbar LED benyttede en 10W gløde eller halogen pære. Du skrev også at dit LED bånd bruger 1,5W pr. m. Hvad sker der hvis du prøver med et 5M LED-bånd alene? Evt. flere korte LED-bånd koblet parallelt, så de samlet kommer over de 5W?
  22. LK IHC wireless HW ver. 2.xx dimmer har ikke noget min. belastnings krav. De er kun LK IHC wireless HW ver. 1.xx dimmer som har et min. belastnings krav på 5-20W alt efter model. Er i sikker på at jeres LED-bånd overhovedet kan dæmpes. Har i prøvet med dimmer af et andet fabrikat? Hvis det er manglende belastning, som er problemet, så skal problemet forsvinde hvis i f.eks. sætter en +20W gløde eller halogen pære, på parallelt med jeres LED-bånd.
  23. Forår og efterår er kendetegnet ved at der kan være pludselige udsving vejret, som gør at nogle dage har man brug for varme og andre ikke. Vi har lige haft et par dage med solskin og 10 grade. I næste uge skulle det igen blive nattefrost og max 4 grader. Det vil derfor nok være smarter at få et tryk så du manuelt kan tænde/slukke for varmen, når vejret ikke passer til sæsonnen. Jeg gætter på at det er @Henning Pedersensom har lavet din varmestyring, så det er nok bedst at du snakker med ham om hvilke ændringer der skal til, eller om du har overset en styrings mulighed.
  24. Et andet problem kan være at dit wireless lampeudtag er HW version 1. Disse kræver en minimums belastning på 20W. Er du under denne kan du få problemer som dit. HW version 2 har ikke noget minimums krav, og burde kunne slukke helt.
  25. Dimmer 350 LR er en relativt simpel dimmer som styres med en enkelt 230V indgang. Det bør være relativt nemt at finde en dimmer som kan erstatte den. Enhver elektriker burde udfra nedenstående diagram kunne finde en alternativ tavledimmer for dig. Hvis de kun kan finde en dimmer med 24V styring, kan du altid ændre dit program til at bruge en 24V udgang i steddet for en 230V udgang. I værste fald kan du sætte et overdragelses relæ mellem IHC udgangen og den nye dimmer. Denne metode kan også bruges hvis den nye dimmer har eget spændings potentiale.
