Anders Krarup
18 -
Alt der er opslået af Anders Krarup
HejJeg vil gerne købe 4 stk opus 66 svagstrømstryk 4 sl el.nr 1092000981 Hvis de er hvide vil jeg give 300kr med portoMVHAnders Krarup
Hej10.0.0.7 Virker hos mig super godt arbejde TAKMVHAnders
nej det var bare en test
Hej med jerjeg kan desvære ikke få programmet til a kører på min pc hvad er det jeg gør galtMVHAndersher er hvad programmet skriver i fejl meddelsenSee the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 85.80.252.103:443 at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.Sockets.Socket.InternalConnect(EndPoint remoteEP) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Int32 timeout, Exception& exception) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.GetRequestStream(TransportContext& context) at System.Net.HttpWebRequest.GetRequestStream() at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at NIhc.AuthenticationService.AuthenticationServiceService.authenticate(WSAuthenticationData authenticate1) at NIhc.Controller.Authenticate(String username, String password, String application) at NIhc.Controller..ctor(String ip, String username, String password, String application) at IHCOutput.Form1.button1_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3615 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------IHCOutput Assembly Version: 1.0.0.6 Win32 Version: 1.0.0.6 CodeBase: file:///C:/Documents%20and%20Settings/dkukraruan1/Desktop/IHCOutput%201.0.0.6/IHCOutput.exe----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3614 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------NIhc Assembly Version: 1.0.0.5 Win32 Version: 1.0.0.5 CodeBase: file:///C:/Documents%20and%20Settings/dkukraruan1/Desktop/IHCOutput%201.0.0.6/NIhc.DLL----------------------------------------System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll----------------------------------------s8bj-wg0 Assembly Version: 1.0.0.5 Win32 Version: 2.0.50727.3614 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.For example:When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
Hej KristianHer er min vis fil mvh Anders
Hej KristianJeg har lidt problemer med at kører den nye version af dit program hvad gør jeg galt. Jeg har lavet et screen dump af hvad der skerSkla med ligge dll filerne et specielt sted?MVHAnders
Hej JanDet er helt rigtigt skumringsrelæet skal have 24v 0v og til input og pir skal til 0 og input
Kan ikke logge ind på ihc contoler over internette
question svarede på Anders Krarup's Anders Krarup i IHC Visual 2.0
Tak for detDet var det jeg manglede altså port 80, det havde jeg bare ikke før i tiden , men det virkede alligevel!! -
Jeg har tjekket min ip og det er stadig den samme og jeg bruger også dyndns -
et spørgsmål tilføjede Anders Krarup i IHC Visual 2.0
HejHåber at der er nogen der kan hjælpe med dette problem, jeg kan lige pluseligt ikke logge ind på ihc'en over internettet, det går fint når man er hjemme på lokal netværket, jeg har kontrolleret port forwarding i routeren og den er sat op til 443, er der nogen der kan hjælpeMVHAnders -
HejSå mangler der bare en version til Android mobiler.
Så er der nyt software 2.7 på lk's hjemmesidehttp://lk.dk/Lauritz+Knudsen/professionel/teknisk-support/IHC-Control-Visual-Software2.page?MVH ANDERS
HejKan man Bruge Kodetastaturet som ringklokke ved tryk på en tastMVH Anders
Hej med jerHvordan for man en ihc controller der kører 2.60 til at snakke sammen med home seermvh Anders
Hej med jerER der nogen som ved om man kan bruge denne av modulator http://www.antonline.com/p_5545-NX_239757.htm istedet for den meget dyre fra lkMVH Anders
Hejher er der nogen nye funktionsblokke fra lk som bla. skulle rette sluk alt kl 0.00 [file name=Blokke_til_nettet_11_02_09.vis size=618940]http://www.ihc-user.dk/media/kunena/attachments/legacy/files/Blokke_til_nettet_11_02_09.vis[/file] Blokke_til_nettet_11_02_09.vis
Hej Er der nogen der har en ide til hvordan jeg kan styre mit genvex anlæg med ihc, det er et GE energy 2
