bartmarchand
Alt der er opslået af bartmarchand
  1. thank you. I've tried the beta, it looks very promissing. Still missing the cover functionallity
  2. Hallo, De IHC-integratie in HA ondersteunt het afdekapparaat niet. Kan iemand me helpen hoe ik een dekkingscontrole in HA kan configureren? Ik heb de cover_template en HACS cover_time_based_synced al getest, maar het werkt niet. heel erg bedankt
  3. I did some scope measurements, signal is exactly the same.
  4. So strange: IHC inputmodule connected to IHC outputmodule: OK Arduino BasicOutput connected to IHC outputmodule: OK Arduino BasicOutput connected to Arduino BasicInput: OK IHC inputmodule connected to Arduino Basicinput: NOK I'm lost...
  5. I've succesfully created a modbus to IHC output converter, with the Basicoutput example. Now I want to do the same for the input module, with the Basicinput example. The Basicinput code is loaded into an arduino, dataline from the input module connected to the arduino. I get no readings from it when I change an input on the inputmodule. Any tips? I think I'm doing something wrong. I'm sure the inputmodule works.
  6. Yes, I know the work of Dingus. He's creating Arduino input and output modules. I want to do the opposite, controlling the output modules with an arduino.
  7. Hello, Is there any information about connection inputmodules and outputmodules to an arduino? I want to replace the controller but need to keep the input and outputmodules. The idea was to program a modbus to ihc converter (or mqtt or another protocol). The modbus part of the arduino is easy, the ihc not.
  8. Hello, Is it possible to connect 2 controllers and make them work like one system? Is there a manual or publication available for it? Thanks
