JanneSjo Skrevet December 25, 2021 Rapporter Share Skrevet December 25, 2021 If you have IHC or Elko living at home. And Home Assistant and Shelly. Have you managed to connect the ihc 24V buttons on the wall to control/dim light that are connected to Shelly/Shelly dimmer, directly or via Home Assistant? What did you do? Citér Link til kommentar Del på andre sites More sharing options...
0 Jonas_R Besvaret December 31, 2021 Rapporter Share Besvaret December 31, 2021 På 25.12.2021 at 16:33 , JanneSjo skrev: If you have IHC or Elko living at home. And Home Assistant and Shelly. Have you managed to connect the ihc 24V buttons on the wall to control/dim light that are connected to Shelly/Shelly dimmer, directly or via Home Assistant? What did you do? I use shelly 2 dimmer with IHC (wireless) and HA, but the switch for the dimmer is supposed to run 230V and not 24V. So not sure that this will work. It run the phase through the switch in the wall. Citér Link til kommentar Del på andre sites More sharing options...
JanneSjo
What did you do?
1 svar på dette spørgsmål
