I have motorized blinds (with stop control) that I want to program.
My system is 6.2 with fw 2.7.220 and I'm using IHC Visual 2.7. Until now I was only using Generic inputs and Generic outputs with the function block (1.1.01. Toggle block with ON/OFF and timer function) so with an input I was "toggling" a switch.
But now I want to be sure that when I press up or down I force switch off the opposite direction, to be sure that the up and down are never switched on at the same time.
I was checking the function block 3.01 for blinds control but I'm not sure how to use it as it can be programmed with alarms, sensors... and I only want manual control, for the moment.
pilfos
Hello,
Do you have any example I can follow?
Thanks!
