I’m configuring everything as switches in configuration.yaml but in HA the siwtch is recognized as an “Entity” and a can’t configure it from UI, and can’t be used as a device in automations.
This is the message I see in the “Entity”
This entity does not have a unique ID, therefore its settings cannot be managed from the UI.
I can switch on/of as an entity but is weird as I need to go to entities then look for the swith and then click in the upper right config icon in the entity so I can switch on/off.
pilfos
Hello,
I’m trying to integrate hassio with IHC.
Is there anything else to configure?
Regards
