IHC Visual in English
pilfos
  På 17.5.2020 at 21:35 , pilfos skrev:
Hello,
Recently I purchased a IHC Control Visual 2 (6.2), but I can't find the IHC Visual software in English.
Where can I download it from ?
Thanks
Expand
I think they stopped translating it - but basicall its all stored in text inside: C:\Program Files (x86)\LK IHC 2.8 Control\IHC Visual - it should be possible to translate it all. Just do a compare of the old version and the new one. The old one had an English version as far as i know
Expand
where can I find older versions?
  På 12.6.2020 at 11:08 , pilfos skrev:
No, I didn't find the english version.. and just today arrived the "toy" :-)
Expand
Well.. I did find old 2.7.2 English version on my disk - I can send you if you wish. In my particular case I had to upgrade to newer 2.8.x FW to get trusted certificates and now it seems that FW does not wish to talk to 2.7 App.. With Danish 2.8 app it talks and pulls project from controller.
Also - was trying to have a help from support chat at lk.dk. Absolutely useless - he has no clue on what am I asking and the only answer - look yourself of ask El installer.
Expand
Yes, please, it would be great! how do you check the FW version?
Expand
There is Firmware loader as part of the package - you have to connect via USB as far I remember.. Or - in IHC Visual - if you are able to connect .. or - somewhere in one of Java Tools that you can run from Controller directly
Expand
btw, I've sent a private message to you with the email address you can send the IHC Visual to
Congrats man !
I have been using OpenHAB with IHC for past 7 years :-) And depends on how strict your underlining OS and application - you might need to upgrade to newer FW since 2.7 FW has expired certificates and SSL connect does not accept that :-)
But enjoy IHC Visual ! :-D
  På 12.6.2020 at 18:24 , dimka skrev:
Congrats man !
Expand
What if you try to connect through USB? ( http://usb ) allowing that domain in java properties?
Do you see the "sprog" option to change language? ( from danish to english). If so, you'll need to restart the application.
Congrats man !
Expand
I believe he will have to update Visual if he update the firmware. And that will start his main issue all over again, as I dont think the latest Visual is available in english :)
Expand
Basically anyone could try and translate all the files in data ... and tada you have english version :)
Any hint to create a quick "installation"?
I created a product input on the left (push button 1 key) (the configure output is disabled). Then a product output (generic).
Finally, I created a function block (toggle block with on/off and timer functions)
I "dragged" the "PB" from the left to the "Toggle" on the right, and the "Output" from the left to the "Output for light" on the right.
I've sent the project to the IHC controller but nothing happens...
(I have the IHC Visual Controller with an input and output module, and a bulb connected to the output module). And I have a IHC v1 at home so I know how to connect everything...
Expand
Done! I was using another input lane... :)
Now is working.
