kerm Skrevet October 15, 2019 Rapporter Share Skrevet October 15, 2019 Hi i installed openhab 2 on pi2 and as soon as i reboot the pi then all my items stop working, then i can remove the link between things and item. rebind them and it will work until i reboot https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.ihc/2.4.0-SNAPSHOT/ i used this guid to install. https://knab183.wordpress.com/2018/11/03/installing-and-using-ihc-bindings-on-openhab2/ Citér Link til kommentar Del på andre sites More sharing options...
0 Pauli Anttila Besvaret October 15, 2019 Rapporter Share Besvaret October 15, 2019 @kerm, could you provide openhab logs (before and after openhab reboot), otherwise it's rather impossible to give any help. Anyhow, something is wrong in your pi enviroment. Do you use any other binding? Do they have same behaviour? Maybe your pi's filesystem is on read only mode? Citér Link til kommentar Del på andre sites More sharing options...
0 kerm Besvaret October 15, 2019 Forfatter Rapporter Share Besvaret October 15, 2019 Hi I have just now flashed the PI with this image openhabian-pi-raspbian-201908050414-gitca0976f-crc6a66b5a1.img then I putty into it and use the guide https://knab183.wordpress.com/2018/11/03/installing-and-using-ihc-bindings-on-openhab2/ I then added 2 dimmers to an item and a temp sensor to another item, then Sudo Reboot After the reboot I get this PS by the way it was not happy with æøå only the first time I loaded from ICH after it restarted if could not understand æøå I therefor renamed all my items in ICH controller events.log openhab.log Citér Link til kommentar Del på andre sites More sharing options...
0 Pauli Anttila Besvaret October 16, 2019 Rapporter Share Besvaret October 16, 2019 @kerm, communication between openHAB and IHC controller doesn't work very well. Most of the communication ends up to timeout, which means that IHC controller didn't send response to IHC binding. You could try to increase the timeout which is by default 5000ms, but not sure if that will solve your problem. What are your IHC controller HW and SW versions? You are using rather old version of the binding (around 1 year old), so I recommend to use newer one. Citér Link til kommentar Del på andre sites More sharing options...
0 kerm Besvaret October 17, 2019 Forfatter Rapporter Share Besvaret October 17, 2019 Hi if i do not reset the PI i am not getting any timeouts and it works fine until i loose power. i have also been running openhab with the version 1 binding for years PS where do i find the latest version of the binding Citér Link til kommentar Del på andre sites More sharing options...
0 Soeren65 Besvaret April 23, 2020 Rapporter Share Besvaret April 23, 2020 På 15.10.2019 at 17:41 , kerm skrev: Hi i installed openhab 2 on pi2 and as soon as i reboot the pi then all my items stop working, then i can remove the link between things and item. rebind them and it will work until i reboot https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.ihc/2.4.0-SNAPSHOT/ i used this guid to install. https://knab183.wordpress.com/2018/11/03/installing-and-using-ihc-bindings-on-openhab2/ Nogen som har et link til hvordan man sætter Openhabian op mod IHC? Har fået Openhabian på en Pi3B og har installeret bindingen til IHC / Elko. Troede så at der ville poppe en "thing" op i min inbox så jeg kunne konfigurere login credentials. Men det gjorde der så ikke... Linket ovenfor "knab183...." virker ikke, men går til noget rekvalmehalløjsa. Citér Link til kommentar Del på andre sites More sharing options...
0 EjvindHald Besvaret April 23, 2020 Rapporter Share Besvaret April 23, 2020 Du skal konfigurere IHC bindingen med ip adresse på controller, brugernavn og adgangskode, hvis du ikke allerede har gjordt det. At linkene ikke fungerer skyldes, at @Gert Fich Kjerslev eksperimenterer med reklame for at sikre midler til at holde denne site kørende. Citér Link til kommentar Del på andre sites More sharing options...
kerm
Hi
6 svar på dette spørgsmål
