http command
Tiago Britici
8 svar på dette spørgsmål
4 timer siden, Tiago Britici skrev:
The IHC is configured on the network with a specific IP address and a Port, correct?
I would like to know if from this address I can send http commands via hyperterminal and / or any internet browser without going through the IHC java application.
You want to send commands to the IHC controller or from the controller
32 minutter siden, Mikkel Skovgaard skrev:
Você precisa de um pedaço de software, se você quer apenas na maneira estática é muito fácil de codificar se você olhar para alguns dos exemplos. Você também pode tentar IHC capitão ou ponte IHC
IHC Captain or IHC Bridge require Hardware (raspberry pi) and I want a software solution like command fusion for example. If the IHC has an IP address and has well-defined IOs, there must be some way to send commands to it outside the java interface.
Yes there is a soap XML API but its not something that is documented in anyway. It requires a login first, then cookies stored and a call. There is plenty of discussion about it in here when we started decoding it. It's pretty flawed
