Astronaut Skrevet May 31, 2019 Rapporter Share Skrevet May 31, 2019 Der synes at være noget galt med det raspberry pi 1.06 image som man kan downloade. Det virker for så vidt fint, men man kan ikke expande filsystemet. Jeg får følgende fejl: May 30 20:40:02 IHCcaptain resize2fs_once[264]: Starting resize2fs_once:resize2fs 1.43.4 (31-Jan-2017) May 30 20:40:02 IHCcaptain kernel: [ 30.200780] EXT4-fs (mmcblk0p2): resizing filesystem from 524288 to 955776 blocks May 30 20:40:02 IHCcaptain kernel: [ 30.200837] EXT4-fs error (device mmcblk0p2): ext4_iget:4697: inode #7: comm resize2fs: bad extra_isize 70 (inode size 256) May 30 20:40:03 IHCcaptain kernel: [ 30.810024] EXT4-fs warning (device mmcblk0p2): ext4_resize_fs:1939: Error opening resize inode May 30 20:40:09 IHCcaptain resize2fs_once[264]: resize2fs: Structure needs cleaning While checking for on-line resizing support May 30 20:40:09 IHCcaptain resize2fs_once[264]: Filesystem at /dev/mmcblk0p2 is mounted on /; on-line resizing required May 30 20:40:09 IHCcaptain resize2fs_once[264]: old_desc_blocks = 1, new_desc_blocks = 1 May 30 20:40:09 IHCcaptain systemd[1]: resize2fs_once.service: Control process exited, code=exited status=1 May 30 20:40:09 IHCcaptain systemd[1]: Failed to start LSB: Resize the root filesystem to fill partition. May 30 20:40:09 IHCcaptain systemd[1]: resize2fs_once.service: Unit entered failed state. May 30 20:40:09 IHCcaptain systemd[1]: resize2fs_once.service: Failed with result 'exit-code'. Jeg har forsøgt med flere forskellige SD kort og flere forskellige Pi'er. Samme fejl. Under normale omstændigheder har man selvfølgeligt slet ikke brug for at expande filsystemet, men jeg havde brug for at smide nogle ting på en linux box og min captain box var "nærmest". Derfor behovet. Anyway, nu har jeg installeret IHC captain manuelt og det virker fint. Citér Link til kommentar Del på andre sites More sharing options...
Mikkel Skovgaard Besvaret June 2, 2019 Rapporter Share Besvaret June 2, 2019 Ja den fejl har jeg også oplevet. Må lige se på det også Astronaut 1 Citér Link til kommentar Del på andre sites More sharing options...
