openHAB2 IHC binding
Pauli Anttila
Update 12.3.2019:
Binding has been merged to openHAB main repository and will available in 2.5 version. Before that, new version can be found from official openHAB snapshot builds.
Before official add-on documentation page is updated, binding documentation can found here.
NOTE. If you have used older beta versions of the binding, beware that there has been some breaking changes lately:
  • Controller address parameter is not anymore ip, but hostname
  • "-channel" suffix is removed from channel types. E.g. switch-channel is just switch.
Even openHAB 1 IHC binding has been rock solid for many years, I finally decided to port the binding to support openHAB 2 features.
Latest version: https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.ihc/2.4.0-SNAPSHOT/
Documentation link
Some improvements / features:
  • By default, binding create channels automatically from project file (currently all dataline_inputs, dataline_outputs, airlink_inputs, airlink_outputs and resource_temperature).
  • Auto creation can be disabled, and channels can be created manually (then all resource id's are supported).
  • Support both Paper UI and thing files configuration.
  • Channels for basic controller information (state, SW and HW version, controller uptime, etc).
  • Trigger channels support (button short press, long press and extra long press).
  • Support multiple controllers (those who have e.g. two controllers environment).
 5b000b95160a8_ScreenShot2018-05-19at14_32_14.thumb.png.4093d93247a17cd4fc3d66307c895976.png
5b000ba2cc62b_ScreenShot2018-05-19at14_33_06.thumb.png.648edf0e40855577f58e973c448514b6.png
  På 3.12.2018 at 14:25 , Pauli Anttila skrev:
Could you enable logs with trace level and try to reproduce the issue?
Expand
Easy to reproduce..
Restart Openhab, and it no longers receives any value changes from the controller.
This is from my main Rpi using the same controller and the same resource ID.
2018-12-03 18:38:30.385 [ome.event.ItemCommandEvent] - Item 'koekken_vasklys_niv' received command 36
2018-12-03 18:38:30.390 [vent.ItemStateChangedEvent] - koekken_vasklys_niv changed from 30 to 36
This is tracelog from the the second rpi with the latest ihc binding:
ihc tracelog.rar
Remember, it´s the same resource ID, so this should have resulted in the item changing from 30 to 36 on the second Rpi using the latest binding. It doesn´t. Actually, it doesn´t even update the values at all. Not untill I disable the binding from PaperUI and Enable it again. THen it starts update.
This is a screenshot from BasicUI right now (the second Rpi with the latest binding), before I disable the binding in PaperUI:
Now I disable the binding in PaperUI and enable it again:
2018-12-03 18:52:05.491 [hingStatusInfoChangedEvent] - 'ihc:controller:elko' changed from ONLINE to UNINITIALIZED
2018-12-03 18:52:09.823 [hingStatusInfoChangedEvent] - 'ihc:controller:elko' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2018-12-03 18:52:55.443 [me.event.ThingUpdatedEvent] - Thing 'ihc:controller:elko' has been updated.
2018-12-03 18:52:56.144 [vent.ItemStateChangedEvent] - ControllerUpTime changed from 669281.808 to 670295.524
2018-12-03 18:52:56.163 [hingStatusInfoChangedEvent] - 'ihc:controller:elko' changed from OFFLINE (BRIDGE_OFFLINE): Initializing communication to the IHC / ELKO controller to ONLINE
2018-12-03 18:52:56.173 [vent.ItemStateChangedEvent] - ControllerDateTime changed from 2018-12-03T16:36:54.000+0100 to 2018-12-03T16:53:48.000+0100
2018-12-03 18:52:56.759 [vent.ItemStateChangedEvent] - koekkenTelestat4a changed from NULL to OFF
2018-12-03 18:52:56.767 [vent.ItemStateChangedEvent] - SoveTemperature changed from NULL to 22.40
2018-12-03 18:52:56.769 [vent.ItemStateChangedEvent] - koekkenVask changed from NULL to 31
2018-12-03 18:52:56.773 [vent.ItemStateChangedEvent] - koekkenTemperature changed from NULL to 23.80
All I did was disable and enable after having restartet openhab.
@Kandersen, IHC binding orders resource ID updates from controller only for channels which are linked to items. Some reason IHC binding doesn't get all channelLinked events (only 3) from openHAB.
2018-12-03 18:35:57.331 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:controllerState
2018-12-03 18:35:57.340 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:controllerTime
2018-12-03 18:35:57.339 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:controllerUptime
So, reason not seem to be in the binding itself but openhab/smarthome core.
  På 4.12.2018 at 08:45 , Kandersen skrev:
But how come it works when I disable and then enable the thing (the controller)?
Expand
Well, you log didn't contain information about that, but I assume that reason is that when you enable and disable the thing, all openHAB core features are up and running (which might not be the case when start the whole system). Could you send log which contains both full startup and then thing restart? Most of the bindings are not interested the channel linked events, so if there is a problem, it might not have influence to other bindings. If my interpretation is correct, we should make a bug report about it.
Expand
Here you go. A new log with a full TRACE for start up, and disable/enable.
ihc tracelog2.rar
Mind you, I´m running openHab 2.4 Milestone (M7) on a Rpi 3B with apt-get hasslefree openHab.
  Quote
2018-12-04 20:40:29.043 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:controllerUptime
2018-12-04 20:40:29.043 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:controllerState
2018-12-04 20:40:29.047 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:controllerTime
2018-12-04 20:41:32.718 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:controllerState
2018-12-04 20:41:32.742 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:temperature6145300
2018-12-04 20:41:32.737 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:controllerTime
2018-12-04 20:41:32.756 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:controllerUptime
2018-12-04 20:41:32.773 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:temperature11011604
2018-12-04 20:41:32.780 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:output13957725
2018-12-04 20:41:32.780 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - channelLinked: ihc:controller:elko:output6512219
Expand
It seems to be exactly like I predicted. Some reason binding didn't get channel linked events for all items in start up. After disable/enable, binding receive more (all?) channel linked events like it should.
  På 6.12.2018 at 11:22 , Pauli Anttila skrev:
@Kandersen, could try this version https://www.dropbox.com/s/2i4bgpeii8qzixp/org.openhab.binding.ihc_2.4.0.201812061319.jar?dl=0
Please, rerun your test with trace logs (full start + enable/disable) and send logs to me, so I can also verify if this solve the problem on your environment.
Expand
Will give it a try tonight.. I saw Kai´s respons in the openhab community. I wonder how this would explain the differences between your Macbook setup and my Rpi setup.
Anyway - We´ll se tonight
Expand
I get an error when openhab tries to load this binding:
2018-12-06 20:08:05.854 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-12-06 20:08:05.928 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2018-12-06 20:08:06.334 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Copenhagen'.
2018-12-06 20:08:06.341 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'da_DK'.
2018-12-06 20:08:14.014 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ihc.items'
2018-12-06 20:08:17.708 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-12-06 20:08:18.308 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ihc.sitemap'
2018-12-06 20:08:18.680 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ihc.things'
==> /var/log/openhab2/events.log <==
2018-12-06 20:08:18.967 [.ItemChannelLinkAddedEvent] - Link 'koekkenVask-ihc:controller:elko:output13957725' has been added.
2018-12-06 20:08:18.970 [.ItemChannelLinkAddedEvent] - Link 'ControllerState-ihc:controller:elko:controllerState' has been added.
2018-12-06 20:08:18.976 [.ItemChannelLinkAddedEvent] - Link 'SoveTemperature-ihc:controller:elko:temperature6145300' has been added.
2018-12-06 20:08:18.979 [.ItemChannelLinkAddedEvent] - Link 'ControllerDateTime-ihc:controller:elko:controllerTime' has been added.
2018-12-06 20:08:18.982 [.ItemChannelLinkAddedEvent] - Link 'koekkenTemperature-ihc:controller:elko:temperature11011604' has been added.
2018-12-06 20:08:18.984 [.ItemChannelLinkAddedEvent] - Link 'ControllerUpTime-ihc:controller:elko:controllerUptime' has been added.
2018-12-06 20:08:18.987 [.ItemChannelLinkAddedEvent] - Link 'koekkenTelestat4a-ihc:controller:elko:output6512219' has been added.
2018-12-06 20:08:19.116 [hingStatusInfoChangedEvent] - 'ihc:controller:elko' changed from UNINITIALIZED to INITIALIZING
==> /var/log/openhab2/openhab.log <==
2018-12-06 20:08:19.152 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.ihc.internal.handler.IhcHandler@e13727': null
java.lang.NullPointerException: null
at org.openhab.binding.ihc.internal.handler.IhcHandler.lambda$2(IhcHandler.java:176) ~[?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:174) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175) ~[?:?]
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) ~[?:?]
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499) ~[?:?]
at org.openhab.binding.ihc.internal.handler.IhcHandler.initialize(IhcHandler.java:176) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh240M7]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh240M7]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?]
at java.lang.Thread.run(Thread.java:748) [?:?]
2018-12-06 20:08:19.192 [hingStatusInfoChangedEvent] - 'ihc:controller:elko' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
2018-12-06 20:08:19.183 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'ihc:controller:elko': null
2018-12-06 20:08:19.858 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://10.4.28.200:8080
2018-12-06 20:08:19.863 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://10.4.28.200:8443
2018-12-06 20:08:20.310 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
  På 6.12.2018 at 19:41 , Pauli Anttila skrev:
Stupid mistakes with controller information channels. Hopefully this version works better?
Expand
Ahh, alot better.. Now it starts, and I get the channel readings (values as well) when the binding was loading. (I didnt restart openhab first, just copied the binding into addons).
But!!
Stop/restart openhab = no channel update :(
  På 6.12.2018 at 21:14 , Pauli Anttila skrev:
new version
Last test today :)
Expand
I´m on it.. I have just cleared the cache and tmp again, and about to restart.. Takes forever when using Rpi and a SD card.. On my main Rpi I have an SSD, it goes much faster.
hang on!
Hmm
2018-12-06 22:32:53.356 [DEBUG] [org.openhab.binding.ihc ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=112, service.bundleid=123, service.scope=bundle, component.name=org.openhab.binding.ihc.internal.IhcHandlerFactory, component.id=19} - org.openhab.binding.ihc
2018-12-06 22:33:09.150 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Copenhagen'.
2018-12-06 22:33:09.157 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'da_DK'.
2018-12-06 22:33:10.825 [DEBUG] [org.openhab.binding.ihc ] - BundleEvent STARTING - org.openhab.binding.ihc
2018-12-06 22:33:10.844 [DEBUG] [org.openhab.binding.ihc ] - BundleEvent STARTED - org.openhab.binding.ihc
2018-12-06 22:33:30.122 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://10.4.28.200:8080
2018-12-06 22:33:30.127 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://10.4.28.200:8443
2018-12-06 22:33:34.819 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ihc.sitemap'
2018-12-06 22:33:36.231 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ihc.things'
2018-12-06 22:33:36.789 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-12-06 22:33:38.539 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ihc.items'
2018-12-06 22:33:39.058 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Using configuration: [ip=10.4.28.6:777, username=admin, password=******, timeout=8000, loadProjectFile=true, createChannelsAutomatically=true]
2018-12-06 22:33:39.074 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Linked channel 'ihc:controller:elko:controllerState' found, resource id 'null'
2018-12-06 22:33:39.078 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.ihc.internal.handler.IhcHandler@789a7e': null
2018-12-06 22:33:39.116 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'ihc:controller:elko': null
2018-12-06 22:33:44.105 [thome.event.ExtensionEvent] - Extension 'package-standard' has been installed.
2018-12-06 22:34:21.410 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2018-12-06 22:34:21.544 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-12-06 22:34:21.680 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-12-06 22:34:27.323 [thome.event.ExtensionEvent] - Extension 'ui-homebuilder' has been installed.
2018-12-06 22:34:27.328 [thome.event.ExtensionEvent] - Extension 'ui-basic' has been installed.
2018-12-06 22:34:27.334 [thome.event.ExtensionEvent] - Extension 'ui-habpanel' has been installed.
2018-12-06 22:34:27.336 [thome.event.ExtensionEvent] - Extension 'ui-paper' has been installed.
We´re back to the same error like when we started.
I´ll try an reboot.
Reboot didnt help
2018-12-06 22:37:31.156 [DEBUG] [org.openhab.binding.ihc ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=117, service.bundleid=123, service.scope=bundle, component.name=org.openhab.binding.ihc.internal.IhcHandlerFactory, component.id=6} - org.openhab.binding.ihc
2018-12-06 22:37:31.175 [DEBUG] [org.openhab.binding.ihc ] - BundleEvent [unknown:512] - org.openhab.binding.ihc
2018-12-06 22:37:31.747 [DEBUG] [org.openhab.binding.ihc ] - BundleEvent STARTING - org.openhab.binding.ihc
2018-12-06 22:37:31.751 [DEBUG] [org.openhab.binding.ihc ] - BundleEvent STARTED - org.openhab.binding.ihc
2018-12-06 22:37:36.882 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Copenhagen'.
2018-12-06 22:37:36.892 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'da_DK'.
2018-12-06 22:37:36.936 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2018-12-06 22:37:36.989 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-12-06 22:37:46.399 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ihc.items'
2018-12-06 22:37:49.687 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-12-06 22:37:50.743 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ihc.sitemap'
2018-12-06 22:37:52.204 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ihc.things'
2018-12-06 22:37:52.484 [.ItemChannelLinkAddedEvent] - Link 'koekkenVask-ihc:controller:elko:output13957725' has been added.
2018-12-06 22:37:52.487 [.ItemChannelLinkAddedEvent] - Link 'ControllerState-ihc:controller:elko:controllerState' has been added.
2018-12-06 22:37:52.493 [.ItemChannelLinkAddedEvent] - Link 'SoveTemperature-ihc:controller:elko:temperature6145300' has been added.
2018-12-06 22:37:52.495 [.ItemChannelLinkAddedEvent] - Link 'ControllerDateTime-ihc:controller:elko:controllerTime' has been added.
2018-12-06 22:37:52.497 [.ItemChannelLinkAddedEvent] - Link 'koekkenTemperature-ihc:controller:elko:temperature11011604' has been added.
2018-12-06 22:37:52.501 [.ItemChannelLinkAddedEvent] - Link 'ControllerUpTime-ihc:controller:elko:controllerUptime' has been added.
2018-12-06 22:37:52.503 [.ItemChannelLinkAddedEvent] - Link 'koekkenTelestat4a-ihc:controller:elko:output6512219' has been added.
2018-12-06 22:37:52.642 [hingStatusInfoChangedEvent] - 'ihc:controller:elko' changed from UNINITIALIZED to INITIALIZING
2018-12-06 22:37:52.681 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Using configuration: [ip=10.4.28.6:777, username=admin, password=******, timeout=8000, loadProjectFile=true, createChannelsAutomatically=true]
2018-12-06 22:37:52.693 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Linked channel 'ihc:controller:elko:controllerState' found, resource id 'null'
2018-12-06 22:37:52.696 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.ihc.internal.handler.IhcHandler@c2f4e2': null
2018-12-06 22:37:52.724 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'ihc:controller:elko': null
2018-12-06 22:37:52.731 [hingStatusInfoChangedEvent] - 'ihc:controller:elko' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
2018-12-06 22:37:53.516 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://10.4.28.200:8080
2018-12-06 22:37:53.520 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://10.4.28.200:8443
2018-12-06 22:37:53.957 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
Hehe..
I think it´s working now.. I just restarted openhab, and I got this:
2018-12-06 22:46:35.236 [DEBUG] [ab.binding.ihc.internal.ws.IhcClient] - 4 new notifications received from controller
2018-12-06 22:46:35.238 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - resourceValueUpdateReceived: [resourceId=6512219, value=false]
2018-12-06 22:46:35.255 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Channel params: channelTypeId=switch-channel, resourceId=6512219, direction=null, commandToReact=null, pulseWidth=null, inverted=null, serialNumber=null, shortPressMaxTime=null, longPressMaxTime=null, extraLongPressMaxTime=null
2018-12-06 22:46:35.289 [vent.ItemStateChangedEvent] - koekkenTelestat4a changed from NULL to OFF
2018-12-06 22:46:35.292 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - resourceValueUpdateReceived: [resourceId=6145300, value=22.40, min=-1000.00, max=1000.00]
2018-12-06 22:46:35.294 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Channel params: channelTypeId=number-channel, resourceId=6145300, direction=null, commandToReact=null, pulseWidth=null, inverted=null, serialNumber=null, shortPressMaxTime=null, longPressMaxTime=null, extraLongPressMaxTime=null
2018-12-06 22:46:35.301 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - resourceValueUpdateReceived: [resourceId=13957725, value=32, min=0, max=100]
2018-12-06 22:46:35.301 [vent.ItemStateChangedEvent] - SoveTemperature changed from NULL to 22.40
2018-12-06 22:46:35.306 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Channel params: channelTypeId=switch-channel, resourceId=13957725, direction=null, commandToReact=null, pulseWidth=null, inverted=null, serialNumber=null, shortPressMaxTime=null, longPressMaxTime=null, extraLongPressMaxTime=null
2018-12-06 22:46:35.311 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - resourceValueUpdateReceived: [resourceId=11011604, value=23.80, min=-1000.00, max=1000.00]
2018-12-06 22:46:35.313 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Channel params: channelTypeId=number-channel, resourceId=11011604, direction=null, commandToReact=null, pulseWidth=null, inverted=null, serialNumber=null, shortPressMaxTime=null, longPressMaxTime=null, extraLongPressMaxTime=null
2018-12-06 22:46:35.317 [vent.ItemStateChangedEvent] - koekkenVask changed from NULL to 32
2018-12-06 22:46:35.320 [TRACE] [ab.binding.ihc.internal.ws.IhcClient] - Wait new resource value notifications from controller
2018-12-06 22:46:35.322 [DEBUG] [.ihc.internal.ws.http.IhcHttpsClient] - Open connection to 'https://10.4.28.6:777/ws/ResourceInteractionService'
2018-12-06 22:46:35.324 [TRACE] [.ihc.internal.ws.http.IhcHttpsClient] - Send query (connectionPool=17855962, clientId=32508048 requestId=2, timeout=13000, headers=[content-type: text/xml]): <?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:utcs="utcs">
<soapenv:Body>
<utcs:waitForResourceValueChanges1>5</utcs:waitForResourceValueChanges1>
</soapenv:Body>
</soapenv:Envelope>
2018-12-06 22:46:35.327 [vent.ItemStateChangedEvent] - koekkenTemperature changed from NULL to 23.80
2018-12-06 22:46:40.274 [TRACE] [.ihc.internal.ws.http.IhcHttpsClient] - Received response (connectionPool=17855962, clientId=21707602 requestId=4, in PT5.294S, headers=[content-type: text/xml; charset="utf-8", date: Thu, 06-Dec-2018 21:47:28 GMT, keep-alive: timeout=900, max=1000, connection: Keep-Alive, content-length: 461, server: Rogatkin's JWS based on Acme.Serve/$Revision: 1.39 $, mime-version: 1.0, set-cookie: JSESSIONID=-1544132842393-56-917]): <?xml version='1.0' encoding='UTF-8'?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<SOAP-ENV:Body>
<ns1:waitForControllerStateChange3 xmlns:ns1="utcs" xsi:type="ns1:WSControllerState">
<ns1:state xsi:type="xsd:string">text.ctrl.state.ready</ns1:state>
</ns1:waitForControllerStateChange3>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
2018-12-06 22:46:40.289 [TRACE] [ab.binding.ihc.internal.ws.IhcClient] - Controller state text.ctrl.state.ready
2018-12-06 22:46:40.292 [TRACE] [ab.binding.ihc.internal.ws.IhcClient] - Wait new state change notification from controller
So at least it´s getting the values at start up now.. Just need to check reboot. 2 minutes...
After reboot it gets the values update as well.. So I guess this is now working..
2018-12-06 22:51:03.424 [DEBUG] [ab.binding.ihc.internal.ws.IhcClient] - 4 new notifications received from controller
2018-12-06 22:51:03.426 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - resourceValueUpdateReceived: [resourceId=6512219, value=false]
2018-12-06 22:51:03.442 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Channel params: channelTypeId=switch-channel, resourceId=6512219, direction=null, commandToReact=null, pulseWidth=null, inverted=null, serialNumber=null, shortPressMaxTime=null, longPressMaxTime=null, extraLongPressMaxTime=null
2018-12-06 22:51:03.474 [vent.ItemStateChangedEvent] - koekkenTelestat4a changed from NULL to OFF
2018-12-06 22:51:03.479 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - resourceValueUpdateReceived: [resourceId=6145300, value=22.40, min=-1000.00, max=1000.00]
2018-12-06 22:51:03.481 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Channel params: channelTypeId=number-channel, resourceId=6145300, direction=null, commandToReact=null, pulseWidth=null, inverted=null, serialNumber=null, shortPressMaxTime=null, longPressMaxTime=null, extraLongPressMaxTime=null
2018-12-06 22:51:03.491 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - resourceValueUpdateReceived: [resourceId=13957725, value=32, min=0, max=100]
2018-12-06 22:51:03.495 [vent.ItemStateChangedEvent] - SoveTemperature changed from NULL to 22.40
2018-12-06 22:51:03.498 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Channel params: channelTypeId=switch-channel, resourceId=13957725, direction=null, commandToReact=null, pulseWidth=null, inverted=null, serialNumber=null, shortPressMaxTime=null, longPressMaxTime=null, extraLongPressMaxTime=null
2018-12-06 22:51:03.504 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - resourceValueUpdateReceived: [resourceId=11011604, value=23.80, min=-1000.00, max=1000.00]
2018-12-06 22:51:03.509 [DEBUG] [ding.ihc.internal.handler.IhcHandler] - Channel params: channelTypeId=number-channel, resourceId=11011604, direction=null, commandToReact=null, pulseWidth=null, inverted=null, serialNumber=null, shortPressMaxTime=null, longPressMaxTime=null, extraLongPressMaxTime=null
2018-12-06 22:51:03.516 [TRACE] [ab.binding.ihc.internal.ws.IhcClient] - Wait new resource value notifications from controller
2018-12-06 22:51:03.520 [DEBUG] [.ihc.internal.ws.http.IhcHttpsClient] - Open connection to 'https://10.4.28.6:777/ws/ResourceInteractionService'
2018-12-06 22:51:03.519 [vent.ItemStateChangedEvent] - koekkenVask changed from NULL to 32
2018-12-06 22:51:03.521 [TRACE] [.ihc.internal.ws.http.IhcHttpsClient] - Send query (connectionPool=10217516, clientId=7468130 requestId=2, timeout=13000, headers=[content-type: text/xml]): <?xml version="1.0" encoding="UTF-8"?>
<soapenv:Body>
</soapenv:Body>
</soapenv:Envelope>
2018-12-06 22:51:03.527 [vent.ItemStateChangedEvent] - koekkenTemperature changed from NULL to 23.80
2018-12-06 22:51:08.390 [TRACE] [.ihc.internal.ws.http.IhcHttpsClient] - Received response (connectionPool=10217516, clientId=18673951 requestId=4, in PT5.203S, headers=[content-type: text/xml; charset="utf-8", date: Thu, 06-Dec-2018 21:51:56 GMT, keep-alive: timeout=900, max=1000, connection: Keep-Alive, content-length: 461, server: Rogatkin's JWS based on Acme.Serve/$Revision: 1.39 $, mime-version: 1.0, set-cookie: JSESSIONID=-1544133110206-57-964]): <?xml version='1.0' encoding='UTF-8'?>
<SOAP-ENV:Body>
</SOAP-ENV:Body>
2018-12-06 22:51:08.410 [TRACE] [ab.binding.ihc.internal.ws.IhcClient] - Controller state text.ctrl.state.ready
I made some clean up and minor improvements to the binding.
  Quote
Controller time.. It seems to be 2 hours wrong.. I cant really understand why.
Expand
Reason why time was not correct was that controller claimed that time is in UTC format in system info data structure but it was not. Now binding ask the time via time manager service, so hopefully it's now correct.
  Quote
Controller Time and controller Uptime  doesn´t update either (in sitemaps).
Expand
Controller time and uptime is not updated automatically. Controller doesn't publish changes and I don't want to poll them, but you can refresh data by rules.
Example by every minute
rule "Refresh controller time"
when
    Time cron "0 * * * * ?"
then
    controllerTime.sendCommand("REFRESH")
end
If you and others could test following version and state is every thing work as should.
https://www.dropbox.com/s/lnlxxnq38b0j739/org.openhab.binding.ihc_2.4.0.201812081313.jar?dl=0
