Pertti Korhonen Skrevet April 29, 2018 Rapporter Share Skrevet April 29, 2018 I would highly appreciate if anybody can help: I have an installation in my house using Visual COntroller/Viewer HW6.1. Now the old laptop died and I cannot log into the controllers with my new PC as I do not know what password the person who did the installations used. Fortunately I have back-up copies of the .vis files and I can open and view them with the current LK IHC 2.7 Control tools package. I have bought new controllers (as spaceports) with HW6.2 and I could like to switch the old controllers to these (giving me also support for iOS11 app). PROBLEM: The LK IHC 2.8 tools package (for HW6.2) does not recognise these .vis Config files to be valid for uploading to HW6.2 controllers. HOW TO SOLVE THIS? I would absolutely not want to rewrite all configurations manually... Citér Link til kommentar Del på andre sites More sharing options...
Lars1 Besvaret April 29, 2018 Rapporter Share Besvaret April 29, 2018 HW6.1 and HW 6.2 uses the same software. If the Visual 2.8 can read the 2.7 .vis files, the problem is probably the FW in the controller hasn't been upgraded to match the Visual 2.8 SW. You can check the firmware version through the adminview. Regarding the password issue. Just connect to the controller using a USB cable. When you connect using USB, there are no password required. You can therefore change the password through the adminview despite not knowing the old password. And last but not least. Please read the manual for how to update the Firmware and connect to the controller using USB or how to access the admin and serviceview. If you run into Java issues with the admin and serviceview, please read the thread "java problemer igen igen igen" Citér Link til kommentar Del på andre sites More sharing options...
Pertti Korhonen Besvaret April 30, 2018 Forfatter Rapporter Share Besvaret April 30, 2018 Thank you very much Lars. I will anyway upgrade my controllers to HW6.2 as I already have them in my storage. So I would like to skip the hassle of upgrading the FW of my current 6.1 controllers and just directly load my back up configuration (.vis) files to my brand new 6.2 controllers. But as I wrote when trying to do it, the Visual software did not recognize the formats of my .vis files. So is there any way I could solve this problem without going back to my old 6.1 Hw? Citér Link til kommentar Del på andre sites More sharing options...
Lars Jacobsen Besvaret April 30, 2018 Rapporter Share Besvaret April 30, 2018 Yes you should be able to load the old project directly to the new hw6.2 controllers. But if you opgrade the firmware in the old hw 6.1 controllers to the latest (se other tread about this) there might not be a need to change or opgrade the controllers. Anyway if you stil have problems then please try uploading the old .vis project files attached here in the tread so that we can have a look. Citér Link til kommentar Del på andre sites More sharing options...
Pertti Korhonen Besvaret April 30, 2018 Forfatter Rapporter Share Besvaret April 30, 2018 Thanks Lars, I will try that again. One more question: many posts refer to the tread "Java problemer igen igen igen" but with the search function on this user group I can only find those references (numerous times) but I have not been able to find the tread itself. How can I find that mysterious "Java problemer igen igen igen" tread? Citér Link til kommentar Del på andre sites More sharing options...
Bjarne Sørensen Besvaret April 30, 2018 Rapporter Share Besvaret April 30, 2018 Pertti Korhonen 1 Citér Link til kommentar Del på andre sites More sharing options...
Pertti Korhonen Besvaret April 30, 2018 Forfatter Rapporter Share Besvaret April 30, 2018 Many thanks Bjarne!! Citér Link til kommentar Del på andre sites More sharing options...
Lars1 Besvaret April 30, 2018 Rapporter Share Besvaret April 30, 2018 På 30.4.2018 at 05:53 , Pertti Korhonen skrev: Thank you very much Lars. I will anyway upgrade my controllers to HW6.2 as I already have them in my storage. So I would like to skip the hassle of upgrading the FW of my current 6.1 controllers and just directly load my back up configuration (.vis) files to my brand new 6.2 controllers. But as I wrote when trying to do it, the Visual software did not recognize the formats of my .vis files. So is there any way I could solve this problem without going back to my old 6.1 Hw? Expand I'm not 100% sure when you see the problem with the format. Is it when you open the .vis file with the Visual SW, or is it when you try to upload it to the controller? If it's the first, try open the .vis file with the old visual SW, make a dummy change and save it with a new name. It might be simple XML error which might be fixed by saving the file again. If it's the last, it can probably be fixed by upgrading the firmware to the latest version on the controller you are trying to uploading the file too. Some old firmwares do not support all the functions of the latest visual versions, and the error you get when you try to upload the program to the controller is something like invalid .vis file. Last but not least. Please take a screenshot of the error and post it here. It's easier to help when we can see the error our self. Citér Link til kommentar Del på andre sites More sharing options...
Pertti Korhonen Besvaret May 3, 2018 Forfatter Rapporter Share Besvaret May 3, 2018 Hello Lars, I have now updated my IHC Visual to version 2.8.4. I succeeded in reading the old config (.vis) files but when trying to connect with my new HW6.2 controllers through USB I get this error message (attached). I cannot log into the controller. This is the first time this controller is powered up.How to overcome this login problem? (I have tried with two options: Username = "admin", no password and then also "admin" as the password as well. Neither option works. Citér Link til kommentar Del på andre sites More sharing options...
Pertti Korhonen Besvaret May 3, 2018 Forfatter Rapporter Share Besvaret May 3, 2018 På 3.5.2018 at 13:17 , Pertti Korhonen skrev: Hello Lars, I have now updated my IHC Visual to version 2.8.4. I succeeded in reading the old config (.vis) files but when trying to connect with my new HW6.2 controllers through USB I get this error message (attached). I cannot log into the controller. This is the first time this controller is powered up.How to overcome this login problem? (I have tried with two options: Username = "admin", no password and then also "admin" as the password as well. Neither option works. Expand Hello Lars, I actually succeeded to get the connection now! I executed the IHC Firmware loader and updated the FW on both controllers. Now the IHC Visual connects ok and I was even able to upload the old configuration files to the new HW62. controllers! Thank you very much for your help - I think I am able to continue with the project now! Mikkel Skovgaard 1 Citér Link til kommentar Del på andre sites More sharing options...
Lars Jacobsen Besvaret May 3, 2018 Rapporter Share Besvaret May 3, 2018 Yes it can be quite a strugle to get the right combination of firmware in the controller, Visual version on the PC and finally the coherrent JAVA with settings. Citér Link til kommentar Del på andre sites More sharing options...
Pertti Korhonen Besvaret October 14, 2018 Forfatter Rapporter Share Besvaret October 14, 2018 Where can I find the ServiceView download file? I have some issues with my configuration and I would like to test it with the ServiceView - but cannot find it anywhere anymore! Citér Link til kommentar Del på andre sites More sharing options...
Lars1 Besvaret October 14, 2018 Rapporter Share Besvaret October 14, 2018 http://<your controller IP> or http://usb if your are connected using USB. Citér Link til kommentar Del på andre sites More sharing options...
Pertti Korhonen Besvaret October 14, 2018 Forfatter Rapporter Share Besvaret October 14, 2018 The old ServiceVirw allowed to make real time simulation and control of the controller. Now with the current tool it appears that the simulation is only off-line showing how the configuration works but it seems not to control the outputs of the real controller. How to fix this? Citér Link til kommentar Del på andre sites More sharing options...
Lars1 Besvaret October 14, 2018 Rapporter Share Besvaret October 14, 2018 The simulation is only available in Visual and has always been offline simulations. ServiceView shows real time data for the program uploaded to the controller and has never had a simulation function. Citér Link til kommentar Del på andre sites More sharing options...
Martin Abildgaard Besvaret October 14, 2018 Rapporter Share Besvaret October 14, 2018 På 14.10.2018 at 20:32 , Lars1 skrev: The simulation is only available in Visual and has always been offline simulations. ServiceView shows real time data for the program uploaded to the controller and has never had a simulation function. Expand In the old Visual 1 it was actually live simulation. There where no serviceview.. But that is waaaay back.. Citér Link til kommentar Del på andre sites More sharing options...
Pertti Korhonen Besvaret October 15, 2018 Forfatter Rapporter Share Besvaret October 15, 2018 Thanks! Where could I find the current version of the ServiceView for downloading? Preferably the English one as Danish is a bit challenging for me (with my Swedish and German plus a bit of imagination I can somehow cope with danish also :) Citér Link til kommentar Del på andre sites More sharing options...
Lars1 Besvaret October 15, 2018 Rapporter Share Besvaret October 15, 2018 The serviceview is a Java program you download from the controller every time you want to run it. There is a link to it in the web frontpage of the controller. http://<your controller IP> Citér Link til kommentar Del på andre sites More sharing options...
