Tiago Britici Skrevet September 25, 2017 Rapporter Share Skrevet September 25, 2017 I have an IHC HW6.1 controller and can no longer communicate with the IHC Remote after upgrading from IOS11 to smartphones. Could you help me? I'm thinking of loading 2.8.4 firmware with an old firmware loader. Can I have problems? Citér Link til kommentar Del på andre sites More sharing options...
0 Lars Jacobsen Besvaret September 25, 2017 Rapporter Share Besvaret September 25, 2017 Wont work. The HW 6.1 is NOT supported by ios11 - period. No workaround. Citér Link til kommentar Del på andre sites More sharing options...
0 Tiago Britici Besvaret September 25, 2017 Forfatter Rapporter Share Besvaret September 25, 2017 1 time siden, Lars Jacobsen skrev: Não funcionará. O HW 6.1 não é suportado pelo período ios11. Não há solução alternativa. I have the old firmware loader. Can I put the firmware in 6.1 or will it crash? Citér Link til kommentar Del på andre sites More sharing options...
0 EjvindHald Besvaret September 25, 2017 Rapporter Share Besvaret September 25, 2017 The 6.1 hardware does not support the encryption required by ios11. The processing power is too little. So even if you had the firmware updated, it would not work. Citér Link til kommentar Del på andre sites More sharing options...
0 Lars1 Besvaret September 25, 2017 Rapporter Share Besvaret September 25, 2017 26 minutter siden, Tiago Britici skrev: I have the old firmware loader. Can I put the firmware in 6.1 or will it crash? I don't think anyone have tried, but the message from LK is the controller will crash, and that's why they don't support anything beyond firmware 2.7.220 on the HW 6.1 controller. Whether you will be able to downgrade if you try and the controller crashes, I don't know. Citér Link til kommentar Del på andre sites More sharing options...
0 Lars1 Besvaret September 25, 2017 Rapporter Share Besvaret September 25, 2017 12 minutter siden, EjvindHald skrev: The 6.1 hardware does not support the encryption required by ios11. The processing power is too little. So even if you had the firmware updated, it would not work. Well. If you could get the firmware loaded and get the controller to run stable, it would work. But it's a big question whether you can get the HW 6.1 controller to run stable with firmware 2.8.4. There most likely is a good reason, why LK less than a year before they released Visual 3 ended support for HW 6.1. Citér Link til kommentar Del på andre sites More sharing options...
Tiago Britici
5 svar på dette spørgsmål
