  1. Today
  2. Sorry to hear that, but not surprisingly, since the Visual 3 controller was never sold outside DK.
  3. Yes I received the message/reply from local (finnish) representative and he said nothing can be done. No spares and nothing. Not helpful at all.
  4. Does anyone know where to find the english version of 1.32? I remember there was many years ago.
  5. Yesterday
  6. Hej Morten, Hvordan er dit Genvex forbundet til HA?
  7. Sidste uge
  8. Lars1
    Ihc tryk og wiser
  9. frank22
    Ihc tryk og wiser
  10. Well. If that's what you prioritize, I would look at Zwave or Zigbee products instead. They are both decentralized too, and are open standards with multiple vendors. With Shelly you really need to look at the details of their full portfolio. As far as I remember not all of their components works on WI-FI, which is the main reason why I decided not to go with them. Did you get in contract with Schneider, and what did they say? My controller was replaced free of charge less than 6 months ago. I only had to pay for the return shipment.
  11. I’ve recently started looking into alternative smart home products, and Shelly has caught my attention. What fascinates me most is its decentralized system—unlike centralized platforms like IHC, there’s no single point of failure. Instead, each Shelly device (relays, switches, etc.) operates independently, communicating directly over Wi-Fi. This means you can control them through Shelly’s own app, Home Assistant, or any other compatible platform. If one device fails, you simply replace it—no complex reconfiguration needed. Plus, they’re surprisingly affordable. For example, a 3-output relay (16A per channel) costs only around €80, making it a cost-effective and reliable choice for home automation. Actually now when I have to find a new Visual 3 controller, which is about 800€, I can buy 10 of these Shelly relays and get rid of the IHC totally.
  12. I got mine replaces about 3-6 months ago. Schneider got a number of Visual 3 controllers back from the technical schools, and they have been able to refurbished some too. Go to lk.dk and click on support. There you will see all the contact info's. My experience is that they answer the phone pretty quickly, but the support form is slower and you might not get an answer at all.
  13. I haven't switched to Shelly, but I've looked at it and decided it's not the right way for me. It's a while back, but as far as I remember the reason is that it's using various communication standards depending on the components, and not all supports all communication standards. You therefore risk having a mixed setup. On top of that, I think there were some strange things with how you control the dimmers. Regarding KNX, please bear in mind that it's not a proprietary product like LK IHC. It's an industry standard, which means there are multiple vendors, so if one decides to drop KNX you still have other vendors to choose from. I'm not 100%, but I actually think Shelly is proprietary like LK IHC, which means you have a greater risk ending up in the same situation with Shelly than with KNX.
  14. Hi. Mine just did the same. When where you able to get it replaced at Schneider? Thought they were all out. /Lasse
  15. A follow-up to my accident. I had a 6 year old Visual 1 version controller on a shelf in the warehouse. I didn't think it would work anymore, but I replaced it with that broken VIsual 3 version. The surprise was when everything went back to normal and all the lighting and other things controlled by the IHC were working in the house. A couple of minor changes still need to be made to work by programming the IHC. As long as I can just get the computers hooked up to it on the serial bus. As I recall, it used to be a pain to get it to play with a Windows machine. I'll send that broken controller to be examined, if there's a component that could be replaced to fix it. Because of this problem, I'm thinking of starting a project to replace the electrical controls in my house away from the IHC system. I have already briefly researched various options, and so far switching to Shelly components seems to be a cheap and quick solution. Is there anyone here on the forum who has swapped the central bus components for Shelly products? For the more expensive ones like KNX I don't want to go with what I learned from this IHC saga. My house also has a well working HomeAssistant installation, so connecting new components to it using e.g. Shelly is completely painless.
  16. It sounds like what happened to my Visual 3 controller too. I called LK and got it replaced. Alternatively, you need to look for an used Visual 2 controller. It will work just as fine as the Visual 3 controller, unless you have LED dimmers, as Visual 2 doesn't support those.
  17. Hi. I'm a first-time writer here. I've had an IHC setup for over 20 years and a few years ago I updated the controller to the latest version. Now one day ago the controller stopped working and I've tried to get it back to life with various tricks. I have a Windows 10 laptop that has previously worked both via USB and over the network (the controller is connected to a mesh router with a cable). The green OK light on the controller is on but it no longer controls any input and output modules. I've started it many times and waited 20 seconds in between. I've connected it to the computer with a USB cable, but the computer programs don't detect it. I've tried the official programs and IHC Starter. They've worked perfectly before. Although I've used the computer and cable very rarely. Many months ago. Also official firmware loader does not recognise the usb at all. The controller failed last fall (it no longer worked via the network connection, I have a HomeAssistant installation and it controls some IHC functions)) and I removed the original SD card. I cloned it from the backup but I've been using the controller without the card and it's been working just fine up until now. IHC Starter says it doesn't recognize any USB drivers, and it can't find the controller via the USB cable or the network connection. The network connection doesn't seem to work at all, even though the connector LEDs are flashing. How do I restore the connection and get the controller working normally again? I'm in an emergency.
  18. Det er korrekt at LK IHC ikke længere produceres, men bortset fra Visual 3 controlleren (som endnu kan ombyttes ved at ringe til LK), er det RIGTIGT stabilt produkt, hvor flere af de installationer som blev lavet tilbage i slut 90'erne da det kom frem, fortsat køre idag uden problemer. Det som plejre at gå i stykker er strømforsyningen, men det er en standard 24VDC strømforsyning, så den kan nemt erstattes. Derudover er LK IHC HW kompatibelt på tværs af versionerne, hvilket vil sige at de I/O moduler som blev brugt sammen med den første LK IHC controller er de samme som blev brugt sammen med den seneste. Har man en gammel TermIHC installation, kan man opgrader installationen ved bare at skifte controlleren. Den anden vej er også mulig, men man kan så ikke benytte den funktionalitet som kom med de nyer controller. At en elektriker taler dårligt om LK IHC undre mig ikke. De vil jo gerne sælge dig noget nyt. Jeg tror aldrig jeg har mødt en håndværker som taler godt om et udgået produkt. Som med alt andet som er udgået, eller er gammelt, så har man en udfordring hvis det går i stykker. Der er dog jævnligt IHC installationer som bliver sat til salg fordi der bliver erstattet af noget andet, så hvis man vil sikre sig, kan man købe nogle brugte komponenter som reservedele. Men hvis din installation ikke er ret stor,kan det være den nemt kan erstattes med noget andet. Prøv evt. at tage et par billeder af din LK IHC tavle, så kan vi hurtigt give dig et bud på hvor stor din installation er. Bruges den kun til lysstyring, kan den sikkert nemt skiftes til noget andet, men bruges den også til varme og alarm, er det straks mere komplekst. Omkring softwaren. Alt efter hvilken IHC controller du har, findes der forskellig versioner af softwaren, men det findes altsammen kun til windos. Alle versionerne kan gratis downloades fra mit lk https://www.lk.dk/mitlk/download-ihc-software/ Det kræver et login, men alle kan gratis oprette sig som bruger. Hvis du har en Visual controller vil du sammen med Visual softwaren få installeret en PDF fil som meget pædagoisk forklar hvad LK IHC er, hvordan det er bygget op, hvordan man programmer det m.m. Jeg vil KRAFTIGT anbefale at du læser denne. Det er den samme hvad enten du installer Visual 2 eller 3, og 95% gælder også for TermIHC og Visual 1, så læs den også selvom du ikke har en Visual 2 eller 3 controller. Du kan finde ud af hvilken LK IHC controller du har, ved at læse denne tråd https://www.ihc-user.dk/forum/forums/topic/11132-hvilken-controller-har-jeg/ Hvorvidt LK IHC er godt eller skidt afhænger af øjnene som ser på det. Personligt mener jeg fortsat at LK IHC er langt bedre end samtlige moderne smarthouse systemer, men det er designet tilbage i slut 80'erne/start 90'erne og siden Visual 2 blev frigivet i 2012 er det stortset ikke vidre udviklet, så har ikke en masse af de features som man ser med moderne smarthouse systemer. Tilgengæld er det et fuldt smarthouse system, og ikke kun lys styring som langt de fleste moderne smarthouse systemer. Derudover har det grundlæggende en stærk arkitektur som gør det flexibelt og nemt at integrer med andre ting via f.eks. OpenHab, Home Assistant, etc. Men det kræver at man er IT kyndig.
  19. Hej måske er det et dumt spørgsmål, men here goes jeg har et hus med Ihc og havde for kort tid siden besøg af en elektriker, han havde kun dårlige ting, og kaos forudsigelser til overs for systemet. Blandt andet spurgte han ind til om vi har programmeringen liggende, jeg var ikke klar over at der høre en programmeringen med til installationen så jeg har forsøgt at finde ud af hvordan jeg kan få fat i programmer til ihc (apple MacOS) ,så jeg kan komme til at backe programmeringen op. Er der nogen som ved hvor jeg kan finde dette program og er det noget man selv kan gøre. Skal men i øvrigt være nervøs over at det virker som om ar systemet ikke længere bliver produceret og i følge elektrikeren så er men “helt fuckt” hvis controleren brænder af for den kan ikke erstattes. Er der en second opinion om det. Som brugernavnet antyder så er min viden omkring ihc enormt begrænset.
  20. Tidligere
  21. Jeg har 13 stk 350 LR (120B1242) dimmere til salg. Er de noget værd? Giv et bud. Desuden 1 stk. 400 UNI (820BA229) - giv et bud. Sendes gerne, men køber betaler fragt
  22. Wavenis er en gamme protokol som stortset ingen benytter idag, så ikke så underligt at alle giver op over for den. Værd dog opmærksom på at Wiser og LK IHC ikke funger sammen. Det er 2 forskellige teknologier.
  23. Hej Bjarne Det bliver vist ikke til noget. Efter info fra Lars1 og lidt intro til Wavenis, virker det lidt for udfordrene. Wavenis skifter kanal efter et mønster aftalt mellem sender og modtager, så det bliver meget svært at følge signalet. Fremgangsmåden måtte blive som en anden bruger herinde har prøvet: at tage signalet fra chippen der styrer tranceiveren, og det kunne nok lade sig gøre men er også et stort arbejde. Men Lars1 oplyste også om Zigbee og Wiser, så det bliver der jeg kaster energien. Der går nok nogle måneder før jeg har noget brugbart.....jeg lader høre fra mig hvis noget interessant opstår. Mvh Martin
  24. Jeg syntes eller selv at jeg forklarede det ret grundigt, og om du kan se grunden til hvorfor jeg vil gøre som jeg gør, er mindre relevant, spørgsmål var ret specifikt og ikke tiltænkt en diskussion om hvorved der er en grund til at gøre som jeg tiltænker. Men som beskrevet, er det et andet system som skal styre tænd og sluk, så jeg kan og vil ikke bruge ICH comtroller til at sætte til 0% eller 100% Det jeg vil med controlleren er at styre lysstyrken (og nogle tids parameter) men det er vigtigt for mig at vide på forhånd om modulerne holder tilstand når der igen tilsluttes strøm, da det ellers ikke vil kunne lade sig gøre med IHC modulerne. Hvis jeg havde modulerne liggende, havde jeg selvfølgelig testet det, også derfor årsagen til at vide det på forhånd er vigtig, inden jeg investere 2500, og risikere det ikke kan bruges som tiltænkt. For mig er det irrelevant hvad der sker ved en strømafbrydelse, wirreless vs I/O moduler, da det intet har med mit scenarier at gøre. det er udelukkende hvordan de holder tilstand jeg er interesseret i at vide. Jeg har nu i mellemtiden lånt mig frem til at modul jeg vil teste med, da jeg stadig ikke føler mit spørgsmål er afdækket herinde. Ellers mange tak for jeres kommentarer.
  25. Hej IHC Nørder. Jeg har skiftet mit ældre IHC system ud med et KNX baseret ( https://luxtek.dk/2023/11/02/udskiftning-af-ihc-med-knx/ ), og har derfor en del velfungerende stumper liggende. Hvis nogen er interesseret, koster det to rimelig gode flasker rødvin, same evt. udgift til fragt. Jeg har vedlagt et billede af enhederne. Controlleren er den super gamle, fra for ca. 30 år siden (DOS Terminal emulator), hvor jeg installerede de første dele af systemet. Men alle de andre enheder kan selvfølgelig fint bruges til nyerere installationer. Jeg har også vedlagt et billede af mit nye KNX system, der fuldt ud erstatter IHC systemet, men det har været et ganske stort arbejde at foretage udskiftningen.
  26. Well. Sommetider har man brug for lidt baggrunds information for at forstå hvad der står skrevet. Mit problem er at jeg ikke rigtig kan se nogen grund til at tage strømmen til 2 wireless dimmer. Hvorfor ikke bare slukke for lyset ved at sætte lysstyrken til 0%. Derudover forstår jeg ikke hvorfor du ikke bare tester dit scenarie? Det vil ikke kræve meget at forbinde en wireless dimmer til en fortråedet udgang på et I/O modul, og så teste om den har samme lysstyrke når du igen tænder for den, som da du slukke for udgangen. Men fred være med det. Min erfaring de gange jeg har haft strømafbrydelse, er at wireless dimmer og andre wireless enheder for den sag skyld holder den tilstand de havde inden strømafbrydelsen, men mere vigtigt de holder også tilstanden selvom strømafbrydelsen kun rammer controlleren, og man ser ikke de hurtige on/off man sommetider ser på de fortåede I/O moduler når controlleren igen kommer op.
