Have you tried to upload the "reset network firmware"? Placed in the download section on this site.
I actually haven't changed the IP address. But restarted the controller anyway. When I type the IP address in the browser, it reaches the front page. But none of the apps can be opened (SceneView, ServiceView, WebSceneView). I then get the message: "Hmmm… can't reach this page" I tried to de-activate the anti-virus: no difference When trying to connect with Visual, I always get the same message : And IHCStarter doesn't manage to connect neither: All work in USB though. PS: I have tried on multiple PC's now, and it always gives the same result.
When you have made changes in network config in the controller, remember to restart the controller.
If you can ping the controller using LAN, it sounds like a PC problem. Maybe antivirus again? If you have telnet on your laptop, you can try telnet <IP> <web port>. It should give you a text version of the browser frontpage.
Indeed, I cannot go through LAN no matter which method I use. Both Visual and IHCStarter work on USB, but none through LAN. I somehow managed to get the front page loaded once in my browser, but could never reproduce it. Always get this nice message after a while: "Hmmm… can't reach this page". I even tried on a very old desktop, running old Java and Internet explorer, but still didn't work. Although this computer always allowed me to connect to the IHC Controller despite the known Java issues. And when I ping the IP Address, all seems OK. No clue what is going on here...
@billekbh Det som @kjeldstrøm forsøger at sige er at LK IHC er 0V styret, hvilket vil sige at dine tryk skal have 0V. Ikke 24V for at virke. En LK IHC indgang går ON når der skabes forbindelse mellem 0V og indgangen. Skaber du forbindelse mellem +24V og indgange, sker der intet (har selv lavet den fejl et par gange)
- 3 svar
- visual3
- v3 control
Is the LAN problem both with Visual and IHCStarter? What happens if you type in the IP of the controller in a browser?
I have been able to access the controller by using IHCStarter via USB connection. I had to deactivate some anti-virus checks to complete it, but it went through at the end. However, still not possible to connect through LAN. I am 100% sure about IP address and port used. Any idea?
Bjarne Sørensen begyndte af følge Udskiftning af IHC anlæg og Brændt dataindgangen af?
Mål om der kommer 24V forsyning til dine inputs. Indgangene tager ikke skade af at få 24V ind da der alligevel sidder en pull up modstand til 24V på input. Det lyder mere til at der er en sikring indsat et sted som er sprunget. Kører inputmoduler på samme PSU som controlleren?
- 3 svar
- visual3
- v3 control
Det var nok bedre med 0 volt til et 4 tryk.
- 3 svar
- visual3
- v3 control
Jeg har et IHC controller Visual 3 setup. I går ville jeg skifte en PIR ud med et 4-tryks udtag, så jeg demonterede PIRen, monterede 4 ledere + 24v til tryk og satte de 3 nye ledere i et inout modul med ledige inputs. Jeg havde dog ikke fået slukket for 24v spændingen som den klaphat jeg er. Status er nu den at INGEN wired inputs virker - jeg har 4 input moduler. Har prøvet at genstarte system, har flashet den nyeste firmware på controlleren og stadig intet. Mine trådløse input virker stadig helt fint. Jeg tænker at næste skridt er at finde ud af om det er controlleren eller mine input som har taget skade. Men er lidt på bar bund med hvordan jeg kan teste den del - nogle gode råd? På forhånd tak.
- 3 svar
- visual3
- v3 control
Hi lars, I'm trying to connect through Visual. tried several versions (2.8.4 and now 2.8.6) I have finally managed to update the firmware to 2.8.4, which helps. At least, now I can connect via USB from Visual 2.8.6. That's a progress All other methods kick me out (Adminview, ServiceView, ...) even through USB I have tried to use IHCStarter, but it didn't find the controller, even when connected via USB. There has been some progress, but not quite there yet ;-)
How do you try to connect? Visual, AdminView, ServiceView or something else? If AdminView or ServiceView are you using IHC starter or similar? If not, the problem is most like Java encryption issues. The workaround is to use IHC starter or similar, or follow the guide line in the FAQ threads.
Hi all, I am new on the forum. I have a pretty old IHC 6.1, which worked well so far. I connected to the controller last time about a year ago. I am trying to connect now, as I want to extend it a bit, and have the same message as Math reported above. I tried both via LAN and USB, and but always get the same message: Ihc controller not detected but <USB> responds to ping I am able to change the firmware using the trick provided by Bjarne. Was on firmware 2.7.200, tried 2.7.148, and then 2.7.199, but still the same message pops-up, and I cannot connect to the controller. Can someone let me know which firmware I should install? Shall I install 2.8.4 although it is not made for HW 6.1 ? Or shall I move back to an older version? Thanks for your help in advance
IHC Firmware 2.7.199 (.zip)
file anmeldte Laurent Pierreu's Gert Kjerslev i IHC Control Visual 2 Firmware
TAK. Tricket virkede stadig i 2025. Sparede mig for at købe nye kontakter.
Det er også helt okay. Jeg troede ikke faktisk at der kunne være interesse for det så hurtigt, og er kun begyndt at skifte ud. Så der går også lige en uges tid inden jeg nok er helt færdig med det og kan tage det ned. Så hvis det endelig er, er du velkommen til at give et bud på det hele samlet. Det vil jeg ikke syntes er forkert, i forhold til at byde på enkelte ting.
Jeg kunne godt være interesseret i det hele (minus wireless), men jeg ønsker ikke at komme i en bud krig med Bjarne og har dårligt tid til at lægge et bud på resten før end om 2-3 uger.
Tak for buddet Bjarne. Jeg vender tilbage senere på ugen hvis det er :-)
Jeg byder 1500 for controlleren. Jeg kunne godt bruge en ekstra til mine el-målere.
PVM begyndte af følge Udskiftning af IHC anlæg
Hej folkens. Jeg tænker det bedste sted at høre om et eventuel salg/køb er herinde. Jeg har postet nogle billeder til mit emne her. Jeg vil ærligt sige jeg ikke har kigget på salgsværdien endnu, men tænker folk herinde er søde til at give en god pris, hvis der skulle være købere. Først og fremmest, undskyld ledningsrodet på billederne. Der er blevet ændret lidt i dag allerede, da jeg har købt Wiser og derfor begyndt at frakoble kabler. Nåh men til det egentlige, så som vist på billederne, har jeg 3 output moduler, visual controller, og power boksen selvfølgelig. Dertil har jeg 2 trådløse tryk, stadig uåbnet i indpakning, og så har jeg 6 som har været i brug. Er der stadig salg i det her, og om noget, hvad vil en salgsværdi være for det her ?
https://www.lavprisel.dk/lk-fuga-wiser-batteritryk-4-slutte-hvid-66079 I forhold til tangenter. Kan det her tryk så styre 2 lyskilder, eller er den øverste kun til dæmpefunktion ?
Yep de er begge i i Fuga design. Men indmaden og den wireless protol og signalet er vidt forskellig.
